05-27-2014, 04:06 PM | #1951 | |
Still Learning
Re: 1969 Short Wide
Your LS1 engines have nearly as many wires, they are a little neater when you get them though. I got a little messy when I did my initial fire up. I will get some pictures of it all when I get it all routed neatly. I promise it's just the original harness, engine harness and cluster harness you are seeing. |
05-27-2014, 06:38 PM | #1952 |
Re: 1969 Short Wide
Oh yeah!!! That is looking awesome! I am glad I won't have as many wires since I'm running the old style FI. I know that when you're done, it will look as great as the rest of the truck.
05-27-2014, 09:47 PM | #1953 |
Re: 1969 Short Wide
looks incredible mike .
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust |
05-27-2014, 10:39 PM | #1954 | |
Still Learning
Re: 1969 Short Wide
Thanks Dean. It's pretty cool that it will fire right up with the key now. |
05-28-2014, 08:42 AM | #1956 |
Re: 1969 Short Wide
Great job Mike, I have faith your wiring will turn out like the rest of the truck, nice and clean. Cool shirt BTW.
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
05-28-2014, 11:14 AM | #1957 |
Still Learning
Re: 1969 Short Wide
Thanks. I think it will be all good too.
05-28-2014, 11:20 AM | #1958 |
Still Learning
Re: 1969 Short Wide
Started figuring out my LS swap A/C fittings last night with Crash_OK's help. Thanks Mark.
It's a combination of the stock LS style fittings and the Vintage Air fittings that came with my kit. Welded them up this morning. |
05-28-2014, 12:01 PM | #1959 |
Re: 1969 Short Wide
Cool shirt and nice job making them adapters!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
05-28-2014, 12:03 PM | #1960 |
Re: 1969 Short Wide
Been making a ton of progress. Nice job on the Wiring, AC lines, sound deadener, etc. looking great!
05-28-2014, 12:46 PM | #1961 |
Re: 1969 Short Wide
Sa-weeet! Shirt and adapters! Make me some, I'm fixin' ta go down that road! (no, really, a pic of what you're up to at the compressor end would be great.)
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
05-28-2014, 12:46 PM | #1962 |
Re: 1969 Short Wide
Does nasquar do any other front ends? Oughta have a tailgate shot on the back of the shirt!
05-28-2014, 01:49 PM | #1963 | |||
Still Learning
Re: 1969 Short Wide
Thanks.
I had to clearance the frame a little to fit the high pressure side. I will take some pics installed tonight hopefully. Quote:
Eddie? |
05-28-2014, 03:44 PM | #1964 |
Re: 1969 Short Wide
Nice job on those ac adapters Mike, it's little things like that I would be lost on I would be looking for somebody who already makes the adapters.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
05-28-2014, 04:38 PM | #1965 |
Re: 1969 Short Wide
A W E S O M E !!!! looking great! let me know if you need those clips?
no charge!
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
05-28-2014, 08:41 PM | #1966 |
Re: 1969 Short Wide
Nice work on the adapters, looks like your coming right along.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
05-28-2014, 11:42 PM | #1967 | ||
Still Learning
Re: 1969 Short Wide
Thanks Jason. It's a slow process as you know. I'm trying to do it as "right" as I can, it's very time consuming. I have been working about 20-30 hours a week. Hard to tell by the progress pics.... |
05-28-2014, 11:49 PM | #1968 |
Re: 1969 Short Wide
Those look great... just like the rest of your truck.. no need to thank me.. All I did was drink your beer...
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
05-28-2014, 11:54 PM | #1969 |
Still Learning
Re: 1969 Short Wide
I mocked up my AC firewall cover and installed my adapters. Overall I think the routing will work out okay. I would like to get some nice extended length elbows to turn the hoses straight down but not sure I'm going to change it.
The suction side is a little close to the exhaust but I'm thinking a heat shield and or some heat shielding tape around the line. Notice I had to notch the frame a little to get the lower hose connector mounted. |
05-29-2014, 01:26 AM | #1970 |
Re: 1969 Short Wide
Good thing I checked out your thread again, I'm dreaming of a/c in my truck again.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
05-29-2014, 07:44 AM | #1971 | |
Still Learning
Re: 1969 Short Wide
Thanks. A/C is a must here |
05-29-2014, 08:56 AM | #1972 |
Re: 1969 Short Wide
Looks great Mike! Nice job on the adapters.
05-29-2014, 09:41 PM | #1973 |
Re: 1969 Short Wide
A/C lines look good. I wish I would have used a bulk head connection something like yours at the firewall. It gives it a cleaner look. Every step you make is another step closer
05-29-2014, 10:55 PM | #1974 | |
Still Learning
Re: 1969 Short Wide
Thanks Jason. digging your new avatar pic
I wish I had known more about my Vintage air kit when I bought it. It was a good deal at the time (2010) but it took a bunch of extra effort to install. The new generations look to be so much better designed. Plus you can route the lines however you want. With this one, I had no choice but to go right through the firewall. Plus the flimsy plastic bulkhead cover just wasn't gonna work so I made this one. I still need finish polishing it but I like it much better than the one that came with the kit. |
05-30-2014, 01:04 PM | #1975 |
Re: 1969 Short Wide
Thanks for the pics! VA or Old air ought to come out with a Doc's blocks type of product for all us LS swap guys.
