Old 05-23-2014, 10:47 PM   #176
ZouchaR
Re: My 63 Project
Auburn
ZouchaR is offline   Reply With Quote
Old 05-23-2014, 10:51 PM   #177
ZouchaR
Re: My 63 Project
And then I added the disc brakes. Here is where I ran into some problems. The brake pads, when installed on the caliper, with the caliper piston all the way back, will not fit over the rotor. It's almost like they have too much pad. So my easy solution is too sand them down just a fraction so they will fit. I also have a small problem with a spacer on the caliper bracket that is about a 16th too wide. Doesn't give any play to the caliper. So I will have to get those machined down a little.
Otherwise, it was a very productive day!
Old 05-24-2014, 12:59 AM   #178
siggyfreud
siggyfreud's Avatar
Re: My 63 Project
Looking good! Can't wait to have my rear end looking that pretty!
siggyfreud is offline   Reply With Quote
Old 05-27-2014, 09:56 AM   #179
1963c-10
1963c-10's Avatar
Re: My 63 Project
nice job on the rear end....doing the same myself in a few weeks.
1964 Short bed trailer
Old 05-29-2014, 05:49 PM   #180
ZouchaR
Re: My 63 Project
Back on the ground!!!
Old 05-29-2014, 05:51 PM   #181
ZouchaR
Re: My 63 Project
So these seats are out of an 02 silverado. I found a pair just like them out of an 01 silverado, but powered. So this should be the style but in grey.
Old 05-31-2014, 01:36 PM   #182
ZouchaR
Re: My 63 Project
Ok fellas. I need some advice. If you look at this picture, you can see that the caliper is right against the mounting bracket.
Old 05-31-2014, 01:37 PM   #183
ZouchaR
Re: My 63 Project
This picture shows the passenger side. Notice the distance between the caliper and the bracket.
Old 05-31-2014, 01:40 PM   #184
ZouchaR
Re: My 63 Project
To me, the passenger side, with the slight gap, looks like the caliper will have room to "float" like it is supposed too.
I contacted the shop that sold me the kit, and EVERYTHING else, bolted right on. They said that if the caliper rides against the bracket, no worries.
What is everyone's thoughts??
If you look at the pictures, you will see a spacer that is welded to the mounting bracket. I can take the brackets to a machine shop and have them machined so the caliper mounting bracket sits closer to the axles flange. But I am not sure if I should.
Old 05-31-2014, 01:59 PM   #185
creep
Registered Loser
creep's Avatar
Re: My 63 Project
The caliper floats on that little spacer so I think you should be ok. you may even be able to pull/pry the caliper out a little so it matches the other side. If you pull the calipers back off you can measure the spacers on each caliper to make sure they are the same size. If I remember correctly when you apply the brakes the piston pushes the inner pad out which in turn pulls the caliper and the outer pad inward away from the bracket. But then again I could be completely wrong.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-01-2014, 12:38 AM   #186
Captainfab
60-66 Nut
Re: My 63 Project
Can you get the outside pad on? If so, once the piston pushes the inside pad towards the rotor, the caliper will move slightly towards the inside, away from the bracket, as creep said.
Old 06-01-2014, 12:48 AM   #187
ZouchaR
Re: My 63 Project
According to the guy that I talked too, he thinks that the piston may not be in all the way. It apparently takes a special tool to turn it back in. So I will take it apart and see if that is the case. The other alternative is to get thinner pads.
Old 06-09-2014, 08:44 PM   #188
ZouchaR
Re: My 63 Project
Man jewelry!!!
Old 06-10-2014, 01:46 AM   #189
ZouchaR
Re: My 63 Project
Time to marry some parts.
Old 06-10-2014, 01:47 AM   #190
ZouchaR
Re: My 63 Project
And the back end.
Old 06-10-2014, 01:47 AM   #191
ZouchaR
Re: My 63 Project
Clutch and flywheel.
Old 06-10-2014, 01:48 AM   #192
ZouchaR
Re: My 63 Project
Throw out bearing.
Old 06-10-2014, 01:49 AM   #193
ZouchaR
Re: My 63 Project
My cheap labor force!!!
Old 06-10-2014, 01:50 AM   #194
ZouchaR
Re: My 63 Project
And together at last.
Old 06-10-2014, 11:02 AM   #195
ZouchaR
Re: My 63 Project
Does anyone have a picture of the stock clutch bell crank attached to a V8??? Since I went from a 292, too this slightly larger motor I don't know how to attach my clutch to the motor. Help please...
Old 06-10-2014, 11:20 AM   #196
1963c-10
1963c-10's Avatar
Re: My 63 Project
There should be a hole just above the oil filter where the stud goes in.
This will be the stud: http://www.classicparts.com/1963-84-.../#.U5chNhNOWUl
Old 06-10-2014, 11:59 AM   #197
ZouchaR
Re: My 63 Project
Will I need to get a V8 bell crank or can I use the I6 that I currently have?
Old 06-10-2014, 12:44 PM   #198
ZouchaR
Re: My 63 Project
And did you have to tap that hole or was it already set up for the stud to screw into??
Old 06-10-2014, 01:17 PM   #199
1963c-10
1963c-10's Avatar
Re: My 63 Project
That's not my block, just an archived pic I had. Some have the provision and some have to be tapped though. If it needs to be tapped, there should be a flat place for it on the block.
Old 06-10-2014, 02:33 PM   #200
ZouchaR
Re: My 63 Project
So here is the view of my block.
