Old 05-28-2014, 01:30 AM   #1
Dzznuts
Dzznuts's Avatar
headlight conversion?
I am looking for a good kit. I bought some bulbs from brothers and they don't fit. Anyone have suggestions? I'm open to anything other than sealed. I'm not really looking to go HID but maybe.
Dzznuts is offline   Reply With Quote
Old 05-28-2014, 01:46 AM   #2
70blackfish
Re: headlight conversion?
i bought mine from these guys they know a lot about what they sell...
http://www.rallylights.com/hella
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 05-28-2014, 02:01 AM   #3
Dzznuts
Dzznuts's Avatar
I did just look at DDM tuning website and I think those might work as well. But I will also give hella a call to. I'm not to sure why these euro crystal ones from brothers don't fit yet, little pissed about the whole thing actually
Old 05-28-2014, 02:24 AM   #4
leddzepp
Moderator
leddzepp's Avatar
If you change your mind about sealed beam headlights, a pair of SilverStar H6024's and a relay upgrade will improve your stock lighting many, many times over.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-28-2014, 02:30 AM   #5
Dzznuts
Dzznuts's Avatar
I don't think I need a harness as I've got a complete harness from autorewire. Is lots better wire than stock and should handle better lights. I have thought about keeping sealed beam but just not sold yet
Old 05-28-2014, 02:56 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Does your new harness have relays to take the load off the factory headlight switch, allowing you to get full voltage to your headlights? Without this, any upgrade you pursue in lighting, whether it be HID, sealed beam, etc, is pointless IMO.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-28-2014, 07:09 AM   #7
MARKDTN
This is very true. What many people don't understand is that you can have the best wire in the world but the switch (and connectors) is a bottleneck. Think of it this way; you have a fire hydrant as a water source, but a 1/2" valve to regulate it. You can't get all that water past the valve no matter how hard you push.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-28-2014, 10:18 AM   #8
Lemield
Lemield's Avatar
X2
I put silverstars on my K20 with the relay harness and it made a world of difference!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 05-28-2014, 11:48 AM   #9
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
First off, definitely use a relay kit. Then, I suggest these. Did this about 18 months ago and they are excellent.
http://www.rallylights.com/h6024-7-r...dlamp-kit.html
Go with the 100/55W bulbs. The high beams are superb on the freeway.
TobyArnot is offline   Reply With Quote
Old 05-29-2014, 09:57 AM   #10
Andy4639
Old member
Andy4639's Avatar
Talking Re: headlight conversion?
First I suggest the relay kit no matter who's wiring you have unless it already has them built into the system. You will never see the full amount of light out of any of them unless you use a relay kit.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-29-2014, 03:47 PM   #11
error4o4
error4o4's Avatar
Where can one find this relay kit?
error4o4 is offline   Reply With Quote
Old 05-29-2014, 03:50 PM   #12
Lemield
Lemield's Avatar
I bought mine at LMC. They seemed to have the best price and the quality was decent. It had an ugly yellow cover on the harness which I took off.
Larry
Old 05-29-2014, 04:36 PM   #13
davepl
davepl's Avatar
The LMC kits are wired backwards. Check previous threads. Be prepared to be popping packard connectors out and putting them in the right place, etc.
I upgraded mine to 4-lamp HID. I used the Kensun (or Kelsun) kit, which I have had for years on the driving lights of my Range Rover without problems.
When you say your bulbs don't fit, do you mean the lamp connector is too big to go through the headlight bucket? I had to drill all of mine out to increase the size, even with the H4 kit I first used.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-29-2014, 05:34 PM   #14
leddzepp
Moderator
leddzepp's Avatar
I bought the LMC harness with the ugly yellow covering off the parts board years ago. Removed the cover, it is plug and play, no wires mismatched or any problems whatsoever.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-29-2014, 06:18 PM   #15
davepl
davepl's Avatar
It could be a bad batch. The complaints started about 2 years ago, which is when I bought mine. Each time I saw a post on the harness someone was having an issue with the wrong lights coming on at the wrong time. Hopefully they've corrected it.
Old 05-29-2014, 06:44 PM   #16
leddzepp
Moderator
leddzepp's Avatar
I've also read of problems with the relays in their harness. I personally haven't had a problem with them...but I have a couple spares just in case.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-29-2014, 07:24 PM   #17
907lukeman
http://www.classicparts.com/Headlamp.../#.U4fBqCiw6Ig
got these and love them
907lukeman is offline   Reply With Quote
Old 05-29-2014, 09:32 PM   #18
1972RedNeck
1972RedNeck's Avatar
Unless you go LED. But then you have to shell out a lot more cash.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
