Motor plate guys
How much did you leave on your motor plate when you trimmed it down? I have my pattern at this stage right now, I had more on the outer edges as when I finish off my cage I'd like to attach a couple more tabs from the forward bars to the plate, then trimmed it a bit more.
I think I should still be able to add the extra attachment point if I cut it like this, if you run a motor plate please post some pictures of how you did yours. ![]() ![]() ![]()
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
Re: Motor plate guys
I trimmed mine to the exact width of the frame.
Justin weight 3480 with driver 1.35 60ft 6.13@111mph 1/8 mile 9.80@131mph 1/4 mile 434 small block all motor |
I was thinking supports off the bars to the plate like you did, thanks for the picture.
meowMEOWmeowMEOW
I"m no help, but 71dragtruck, your engine bay is purdy.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Mine is like yours in the pic but flush with the outer edge of the frame.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Here's a picture of the mount without the plate in the way.
Yes that's exactly how I was thinking of tying it in.
Not sure why my template looks like it hangs over the rail so much and angles out in the picture???
It is actually only about 1/4 over the edge and goes straight up on the sides.
Are you going to install a mid plate also?
Eventually yes, have one ordered but right now there is a header tube in the way, have it booked for a set of custom headers this fall so will risk this season without one. I can leave the passenger side motor mount on if that would make any difference but the drivers has to go, and a limiter bar will go in, or both mounts out, and a pair of limiters in are my current options.
![]() Join Date: Mar 2008
NHRA Super Street 469C It only runs 10.90 at 156 mph |
Mine is mounted to a plate that spans the frame rail top to bottom. Thats the best pic I have. You will also need to do something with engine limiters. Mine bolt to the old motor mount bosses on the block. They then went forward to the old crossmember. Make sure you use a quality rubber trans mount.
I'm running a Prothane poly mount and have a limiter for both sides.
It's Better With Nitro
I fab'd my chassis mounts to index the motor plate, so I didn't have to muscle anything around - I welded a small tab as a lip for the bottom of the plate, and machined the angle on the ends of the plate to correspond with the angled vertical of the chassis mount - this worked as guides as the engine was dropped down.
![]() …it ended up being a smaller version of Jerry Bickel's plate mount: ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#15 |
#16 |
Registered Truck Offender
Vacuum pumps water pump etc is intended to be on the face of the motor plate.
But..... Alternators are always a PITA,, plan ahead ![]()
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#17 |
