#15 |
Re: 85 SM465 Transmission swap question
I believe not towing in 5th gear with the NV4500 was related to extremely high torque engines like the Cummmins 6BT. Towing in O/D would cause the 5th gear nut to back out resulting in loss of that gear. There are fixes for this issue but it may be a non issue behind a 350.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
| Bookmarks |
