06-01-2014, 06:10 PM | #1 |
Suburban slider rear window repair
Well my slider popped the window off the track, low and behold its those pesky rollers.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
06-01-2014, 06:15 PM | #2 |
Re: Suburban slider rear window repair
The roller broke so i had to make a quick repair
06-01-2014, 06:25 PM | #3 |
Made a temp roller out of mirror bolts and the hard plastic washers, ground the head off to put inside the slider with the washers.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd Last edited by BIG V; 06-01-2014 at 06:30 PM. |
06-01-2014, 06:28 PM | #4 |
Then i knocked out the old stud, drilled the hole out to fit, and put this bugger in.
