Old 01-08-2004, 01:51 AM   #1
cochino12
It followed me home?
cochino12's Avatar
Originally posted by N2TRUX
Since I didn't want to cut the 77 up, I gave the orders for them to go as low as possible without having to cut the bed. You can see the results below.
My front is as simple as the rear. We removed the springs, and factory bump stops. Then they installed the bags and custom bump stops were built. When the system is aired out, I still have at least an inch before the tire rubs the fender liner. My fender liners are still stock.
so you didnt do the install on your own? How much should I expect to pay if I took it to somewhere to have done? I figured the front would be easy enough to do on my own?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
