Drop Spindle Selection
I hate to be the guy to post another drop spindle question, but here goes.
I am looking to order drop spindles tonight and am trying to decide between ECE and CPP. It is my understanding that ECE spindles will move the wheels out about an inch and CPP will keep the wheels in the stock location. My goal is to build a moderate performance street truck. I am probably not going more drop than the spindles will give me, so I don't think I absolutely need the wheels tucked in. I am just looking for good handling. My question is will the ECE springs giving the wider stance make a difference in handling? I always thought wider was better. ECE has also helped me out in the past, so I would like to use them. Thanks |
![]() Join Date: May 2011
Re: Drop Spindle Selection
is this on your 71?
Drop spindles widen the track width if you are converting from drum to disc because stock height disc spindles are wider than drum spindles. You wont have a width difference with drop spindles if your vehicle already has discs. CPP sells 2 different spindles, standard width and "modular" spindles. Modulars narrow up the width of disc breaks for fatter tires so you dont rub the fenders. Wider is better but I dont know if you will notice a big difference from that 1.5" of extra track width. I would go with ECE and there McGaughys drop spindles.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
ECE is the way im going...good quality and you cant beat the price....
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
I noticed the question about the drop spindles, what is a good spindles to go with im wanting to drop mine in the front about 2'. and does anybody know what the stock ride height is on 81 c10 front and back? thanks. newby to lowering need all the help i can get. i wanting to lower and not loose the ride. prob. 2' in the front and 2' in rear?
#5 | |
