Old 06-03-2014, 04:25 PM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Painting the Dash (still in the cab)?
Originally Posted by Ronw435 View Post
Thanks 1963c-10. I guess the worse thing that can happen is breaking the windshield, but with Deep Ellum Auto Glass being close by it sounds like an alternative.
In seriousness, the only advice I can give is that;
you might as well factor a new windshield into budget, and then be happy if you don't need it. When taking them out, its really common to either cut the gasket (eliminating the "press" fit), or to use those metal hook deals. On an older windshield, its possible to chip the outer lamination, and when you go to reinstall; craaaack.
They can be removed, but its gotta be in perfect shape, and removed in a way preventing chipping on the edges. If those things are not an issue, then it should come out and be able to be reinstalled later without any more headache than usual.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
