Rochester single barrel carb spacer needed
Greetings
Anyone know where I can find a 1/4" thick spacer (heat block) for a 1971 Rochester single barrel carb? I'm trying to cure a hot shutdown fuel boil over problem. The fellow on ebay that sells em is "on vacation" so his spacers are currently not available. thanks JohnG |
Active Member
![]() Join Date: Jul 2007
Re: Rochester single barrel carb spacer needed
I owned several mono's in my time, starting back in the mid 60's and never had a problem with boil over. That intake manifold should not be getting that hot.
You might need to check to see what's causing that first or if in fact it really is boiling over. It could have the exhaust obstructed. A good place to start is the baffle for the heat riser. Sometimes they get rusted so they won't move.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#3 | |
I did a net search and couldn't find a spring/replacement part for the inline 6. cheers JohnG |
I've got the same issue. I know my 292 is bored to 318, and these engines run hot in original form.
have you had any luck finding a cause of excessive heat? or any luck finding a spacer? thank you |
![]() Join Date: Nov 2001
Did you check Speedway Motors for a spacer?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
I used my IR temp gauge and "scoped" the bottom of the carb. Temp was around 275F about 10 minutes after the engine was shut down (heat soak).
![]() The exhaust manifold "valve" appears to be working (not stuck) so I'm a bit at a loss why the carb is getting so hot. I still haven't found a phenolic spacer but the carb rebuild kit I recently purchased has a ~1/8" gasket that might work as a modest heat shield. Haven't had time to rebuild the carb but should get to in in a month or so. JohnG |
A spacer for a 235 6 cyl. should work.
how hard is it to make one?
OK, here's my big update:
Got a carb rebuild kit and there were a couple carb-manifold gaskets included. One of the "gaskets" was ~0.20" thick. After installing this thick gasket I had to bend the choke rod a bit. I also wrapped the fuel line with a bunch of aluminum foil and aluminum tape to shield it from the exhaust manifold heat. Bottom line is that the carb no longer percolates fuel after a hot shutdown. My thermometer "gun" indicates the carb bowl hits a peak of 150F after a hot shutdown. Previously it was well over 200F. cheers JohnG |
#10 | |
Active Member
Here's a pic of the carb with the "thick base gasket". The gasket measured 0.25" in thickness. I've had a chance to run the truck under hot conditions and no more 'hot shutdown' fuel percolation. Wohooooo..............
![]() Edit: Can someone give me a good suggestion for a pump-carb fuel line for a 250 ci six cylinder 1971? The PO FUBAR'd the nut at the end of the fuel line. Last edited by Carl Spangler; 06-03-2014 at 07:41 PM. |
#12 | |
Active Member
Might check local places to see if they do that.
