Old 06-05-2014, 02:35 PM   #1
1972BlueC20
1972BlueC20's Avatar
U Joint going out?
I'm getting a bad clunk when I put my truck in reverse, and if I nail it from a dead stop it feels like something in the middle or rear section of my truck is loose....does this sound like the U Joint?
If so, is it easy to replace the u joint?
1972BlueC20 is offline   Reply With Quote
Old 06-05-2014, 03:54 PM   #2
steelhorse
steelhorse's Avatar
Re: U Joint going out?
You will need to get under it and check where the slack is. It could be a u joint, center bearing or play in the read diff.
steelhorse is offline   Reply With Quote
