#301 |
Re: '72 Drop member... "Betty"
Drive line in. 2" spacer on carrier bearing
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
#302 |
What would you like to see?
#303 |
Big Willie trickin out the rearend vent!
#304 |
![]() Join Date: Jan 2010
Pretty cool trick with the breather.
#305 |
I'm just glad to be here!
I have nver seen that done. Looks like a good spot and I just might have to steal that idea...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#306 |
Prestige Worldwide
![]() Join Date: Feb 2001
#307 |
Hmm... That's pretty cool. Do you mind sharing how the connection was made from the tube to the filter? How does it stay in place?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#308 | |
put a freeze plug in the trac bar hole and drill to size. Bend ya up some fuel line and walla
#309 |
Fans mocked up. I'm going to paint the aluminum shroud satin to machine the rest and blend it in a bit
#310 |
Sweet! Thanks for the info! Fans and shroud look good. Did you build it?
#311 |
No it came as a kit with fans
#312 |
![]() Join Date: Apr 2010
Who makes the fans & shroud kit? Sorry If I missed that from an earlier post
Thanks, Wade |
#313 |
![]() Join Date: Dec 2006
Fans look good, I'm interested in the kit as well
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#314 |
![]() Join Date: Mar 2010
Looks great. Keep up the good work.
#315 | |
#316 |
Thank you. I'll checked out. I'd like to buy just the fan/shroud set up
Wade |
#317 |
Ya that's what I did
#318 |
Hey Seth,
They show a high performance 12" that is a straight blade draws 25 amps and rated for 1600 cfm's. Is that what's in your set up? Are they loud, and do they move a lot of air? I'm looking to just put two fans to the factory 4 core radiator with no shroud. Thanks, Wade |
#319 |
Can u list the address for PML valve covers?
#320 |
Yourcovers.com
I bought the polished ones and painted them. There is still some sanding and priming you will need to do around the script
#321 | |
#322 |
Shroud painted and willie bent up some clean Tranny lines
#323 |
Laid Back
Looking good!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#324 |
![]() Join Date: Nov 2013
Stunning build. Add yours to my list of builds on here I get inspired by for my build.
#325 |
Little N2billet idea I stole
