Old 06-04-2014, 07:00 PM   #1
TBONE1964
Cluster King
TBONE1964's Avatar
??Oil Pressure high limit on gauge??
Hello all,
I am wondering if anyone knows exactly what the high mark on the oil pressure gauge represents in psi? I know on the 67-72,s it is 60 or 80 depending on the gauge and they are marked to identify.
Even the 50-54 gauges are marks by a number of PSi but the 64-66 gauges only have marks.
Is it 30 lbs or 60 lbs or 45 lbs??? I know what my guess is but want some input from others please.
Any help is greatly appreciated
Thank you,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 06-04-2014, 09:54 PM   #2
VictoriaHardware
VictoriaHardware's Avatar
Re: ??Oil Pressure high limit on gauge??
Can you hook up a '64-'66 gauge to air pressure on a bench along with an known accurate gauge to check it?
VictoriaHardware is offline   Reply With Quote
Old 06-05-2014, 07:39 AM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
I may have to try that if no one can answer my question. It would be just as easy for me to use my 72 pick up (with 60 lb gauge) and connect the 64 oil pressure gauge up to my existing oil line and compare.
Thanks for the tip,
Tom
Old 06-05-2014, 08:21 AM   #4
1963c-10
1963c-10's Avatar
I was always under the assumption that the (60-63 at least) gauges were 0-60 psi
1964 Short bed trailer
Old 06-05-2014, 09:41 AM   #5
AcampoDave
AcampoDave's Avatar
I get the impression that my stock guages give exaggerated readings which I attribute to fatigue of the mechanisims due to so many years of use. I wonder, is that possible?
AcampoDave is offline   Reply With Quote
Old 06-05-2014, 10:25 AM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
Yes, that would be a good assumption due to the fact that any factory gauge is 50+ years old. They do tend to loose there ability to be accurate. Some say and believe that they were never accurate to start with. I suppose it will be one of those arguments.
My objective hear is to learn exactly what the high graduation mark on the gauge represents in PSI since it is not labeled on the gauge.
Old 06-05-2014, 07:13 PM   #7
ray_mcavoy
The numbers on the lens seem to indicate that the high mark should be 60 psi.
Out of curiosity, I gathered up a few of the 64-66 clusters I have in my stash of spare parts and did some testing like VictoriaHardware described. I hooked them up to the adjustable air pressure regulator & gauge that I use for painting.
4 out of the 5 oil pressure gauges I tested seemed to be pretty accurate. They were on the middle graduation mark with 30 psi and on the high mark with 60 psi (give or take a couple psi). The oddball gauge (and worst looking of the bunch) seemed to be a little bit non-linear. That one was reading at the half way mark with only about 20 psi and was getting up close to the 3/4 mark with 30 psi. But wasn't very far above the high graduation mark at 60 psi.
ray_mcavoy is offline   Reply With Quote
Old 06-05-2014, 07:22 PM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
Ray,
This is perfect and I cannot tell you how much I appreciate your time. The question is answered. 4 out of 5 convinces me that it is a 60 psi gauge on the high mark. So did you just use compressed air with a compression fitting for the back of the gauge and regulate the air?
I don't have access to an air compressor currently so that is why I was looking for help with this.
Thank you again,
Tom
Old 06-05-2014, 08:07 PM   #9
ray_mcavoy
You're welcome Tom!
Yes, I just fed regulated compressed air to the gauge being tested. And adjusted the regulator pressure while comparing the reading on the regulator's gauge to the reading on the oil gauge being tested. I used a scrap section of stock oil line (that already had the correct compression fitting for the gauge) along with some adapter fittings to join the other end to the compressed air line.
Old 06-05-2014, 09:39 PM   #10
AnlaufJohn
Have you thought about hooking up an electronic oil pressure gauge to the port at the front of the block and see how much the pressure drops from lubricating the engine?
Silly me, that's one of the first modifications I made.
I show maximum pressure + with the factory gauge and 55 pounds from the front sender at cold start up.
After driving in town for 1/2 hour or more, at idle the factory shows less than 30 and the other one shows 25, +/- 3 pounds.
I run 15w-40 motor oil, so that is one reason the start up pressure reads so high.
Eugene, Oregon
Lucy's Limousine
1966 C-10 LWB
283 w/ 2bbl, OE carb and dist.
4 spd (granny 1st) w/ 3.73 rear end
AnlaufJohn is offline   Reply With Quote
