Old 06-06-2014, 02:31 PM   #1
ScottH
ScottH's Avatar
Exclamation Drop spring issue
Just installed a new set of CPP 4" rear drop springs. Installed the springs positioned in the same way, new KYB lowered shocks, new cups & hardware both sides. After installing everything the truck is now sitting about an inch higher on the right side. If I measure the installed springs, right one is about 1/2 taller than the other. Unfortunately I did not check the height of the springs next to each other prior to the install. Also I did not touch the stock panhard bar.
Would leaving the stock panhard bar somehow cause this affect?
Or could I have a mismatched set of springs?
Any ideas or suggestions are appreciated. Frustrating after all the work.
Scott
1963 C10 swb fleetside
1966 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 06-06-2014, 04:24 PM   #2
cdowns
cdowns's Avatar
Re: Drop spring issue
it is the infamous chey lean normal due to tweaked frame with 40years of hard use
Old 06-06-2014, 04:25 PM   #3
RustyBucket
RustyBucket's Avatar
I'd think the stock length panhard bar would be in a bind w/4" drop springs. Looks like it'd be trying to push the rear end. The distance between the 2 mounting points changes was the truck goes up & down. The previous owner had 3" springs and the stock bar on my '71 and it seemed ok but too high. I swapped to the 4" with a 1" lowering block and an adjustable bar. Levelled out the stance but the ride is too stiff. Well,... it levelled out the stance after I cut 1 coil off the front.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 06-06-2014, 05:15 PM   #4
ScottH
ScottH's Avatar
I know its been suggested that with a 4" drop I should install an adjustable bar so I will probably just order one and go from there. I could always remove the original bar to see what the affect is.
Old 06-06-2014, 05:53 PM   #5
Lattimer
Lattimer's Avatar
I would pull the springs back out and measure them before I went any farther.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 07-04-2014, 07:25 PM   #6
WhippinSaw
WhippinSaw's Avatar
Not sure if you got this figured out yet, but I ordered a set of front stock springs from classic parts and after install one side was higher than the other, ordered a set of moog springs and the truck was back to normal, The bad springs were the same height , but compressed differently, in short I got a bum set of springs.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
