Uh Oh, I screwed up!
OK... I did a bone-head thing. I wasn't totally awake this morning. I added some Barz Leak Repair to the 1977 Chevy Truck but mistakenly added it to the power steering reservoir instead of the engine oil reservior. Will it damage the system or can I go home and suck it out with a turkey baster? Afterwards, can I add back the correct power steering fluid? I feel pretty stupid. Any advice is greatly appreciated.
Respectfully, Adam 1977 Chevrolet ![]() |
Re: Uh Oh, I screwed up!
I would think it would be fine once you flush it out good. Take the return line off and place it in a container. Have someone crank the truck, not start(unplug your ignition). As the fluid pumps out, put new fluid in; until it runs clean. That should be good.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed ![]() ![]() |
Another Day, Another Dollar
Bars leak shouldn't go anywhere in your truck. Period.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
I thought that stuff went into the cooling system.
Agreed! Fix the problem
They make many different potions.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
if you put bars leak in your coolant say good bye to your heater core
I've heard that for years and years, but haven't seen or experienced it. Kind of odd considering the bazillions of units they've sold. I've also heard most, if not all, manufacturers put some form of stop leak in their new cars.
had it happen to me it has to do with where your heater core is mostly happens in cars the crap settles in the core and then plugs it up
they sell lots cause not everyone is a tech and it is a temp quick fix when used the car is already on its way out so people buy it then end up getting the car fixed right or it gets sold
just like STP its just a bandaid
GM doesn't put STP in new cars.
I flushed the system today and then bleed it out really well. Thanks for the advice.
