Old 06-08-2014, 12:04 PM   #1
drillrod
Battery cable connection
I am restoring a 72 K5 CST with AC. Can someone tell me where the negative battery cable is suppose to bolt on at. I have seen them bolted on in several different places,(chassis,motor,AC bracket, etc.). Thanks
drillrod is offline   Reply With Quote
Old 06-08-2014, 12:28 PM   #2
kwmech
Re: Battery cable connection
I like to put them down low by the fuel pump. Hole below the push rod hole. Use a star washer
Old 06-08-2014, 03:18 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
On an A/C truck I believe it's one of the A/C compressor brackets as shown here: http://67-72chevytrucks.com/vboard/s...d.php?t=524251 (this is how my negative cable is routed).
Old 06-08-2014, 08:12 PM   #4
drillrod
thanks for the info, that helps a lot.
