Old 06-08-2014, 02:43 PM   #1
uxdesigner
4l60e slip yoke
Finally started working on the connecting the driveline and realized the slip yoke I have (TH400) is different from the 4l60e. I have the stock driveshaft, anyone know what the u joint sizes are or would it be best to hit the part store and verify prior to ordering a new yoke?
uxdesigner is offline   Reply With Quote
Old 06-08-2014, 04:47 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 4l60e slip yoke
Just get one for a 350 turbo or 700r4, they're easy to find.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-09-2014, 12:52 AM   #3
uxdesigner
Re: 4l60e slip yoke
Thanks, found a few online. Would it be 1310 or 1350? Does that even matter?
Old 06-09-2014, 09:56 AM   #4
wgeyer88
Re: 4l60e slip yoke
Yes it does matter. If your truck is a 1/2 ton it should be a 1310. I would measure the u-joints on your drive shaft to make sure.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 06-09-2014, 10:39 AM   #5
Hart_Rod
Hart_Rod's Avatar
Re: 4l60e slip yoke
I have a nearly new 1330 rearend yoke, let me know if you are interested.
Hart_Rod is offline   Reply With Quote
Old 06-11-2014, 03:57 PM   #6
uxdesigner
Re: 4l60e slip yoke
Great information, really appreciate your help. I measured and its a 1310, thanks for the offer Hart_Rod.
Old 06-11-2014, 04:57 PM   #7
desertdogg
desertdogg's Avatar
Re: 4l60e slip yoke
I will be working on the drive line soon. I called a local drive shaft company and they said the slip yoke should only go in about 3/4 of an inch?.... Is this what everyone is finding??
Trying to get thru my LS swap
desertdogg is offline   Reply With Quote
Old 06-11-2014, 05:22 PM   #8
truckdude239
truckdude239's Avatar
Re: 4l60e slip yoke
ummm mine goes in almost 2 inchs 3/4 inch is nothing
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-11-2014, 07:23 PM   #9
clinebarger
Re: 4l60e slip yoke
Is the driveline shop telling you to install the yoke & then measure for the driveshaft?
That is not the way to measure, You measure from the end of the extension housing to the center of the rear U-joint, And the Shop figures out everything else.
http://www.dennysdriveshaft.com/app/...iagrams/b.html
clinebarger is offline   Reply With Quote
Old 06-12-2014, 03:01 AM   #10
desertdogg
desertdogg's Avatar
Re: 4l60e slip yoke
Something like that..I'm confused, by extension housing, do you mean the end of the transmission like where the yoke slips in ?
Old 06-12-2014, 07:26 AM   #11
truckdude239
Re: 4l60e slip yoke
Yes my drives haft shop wanted from the fatherest point on the Tran which was the out put shaft
David fuller
2000 Tahoe 5.3l 378
Old 06-12-2014, 03:48 PM   #12
desertdogg
desertdogg's Avatar
Re: 4l60e slip yoke
Originally Posted by truckdude239 View Post
Yes my drives haft shop wanted from the fatherest point on tjoint ran which was the out put shaft
OK, I so I. Measure from the end of the transmission to the differenttial where the u joint fits in??
