Old 06-06-2014, 09:04 PM   #1851
cubber
Re: 1968
Glad to hear you're back at it!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 06-07-2014, 09:10 PM   #1852
gdavis
gdavis's Avatar
Re: 1968
hey Matt, so am I. I tried to adjust the hood latch but no go. I have to shift the right fender about 1/16 of a inch. It is 1/16 from being right in the front. By shifting the fender that 1/16 of a inch well that will almost set the latch dead center. I got time to kill until my wiring harness arrives. Then I will start the wiring. I have put it off long enough. It is something I am not looking forward to. But it will not be as bad as I think. I hope. I been buying wire looms and straps and all the tools I need to do the job. All I need now is motivation. After I wire the truck I can start the engine, want that be something. Two years in the making.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 06-08-2014, 10:03 AM   #1853
Xeen
Xeen's Avatar
Re: 1968
George have you measured your front clip to see if it's square, if not it can throw off your alignment for your hood latch, you may have to loosen everything up and move your radiator support ever so slightly then once your front clip is square then it should be no problem to get the hood latch to line up.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 06-08-2014, 08:14 PM   #1854
gdavis
gdavis's Avatar
Re: 1968
My pass side fender does need to go forward that 1/16 of a inch. but to answer your question I have not measured to see if it is square. I will do that after I shift the fender. But thanks for re-minding me to do that. See you can teach a old dog some new tricks. I got a few days before I get my wiring harness so I will work of that. Thanks a lot Bryan
Check out Patches
Old 06-09-2014, 08:42 PM   #1855
gdavis
gdavis's Avatar
Re: 1968
Well, today I adjusted the hood. All I have to do was loosen the bolts and push down on the back of the hinge and that brought it where it suppose to be. I had to shim the cowl on the drivers side front bolt. I put two 3/8 washers under the cowl lip and now that is perfect, I didn't like the shims that came out of the hole. I shifted the pass side fender that 1/16 of a inch and I am happy with that. I loosen the bolts in the radiator core support and centered the bolts in the core mount. I put two washers in the hole so that the core support will not shift any more. The bolts in the door frame for the cowl, will I had to use a rat tail file on the hole and push down on the back and boy what a difference.
It seems that everything I touched today turned out great. I did notice that the head light bulb on the pass side needs to turn about 1/4 turn so it will look straight. But that is another day. only about 5 minutes of work. I figured I better start on the truck again if I want to meet my deadline. I want to drive the truck on my birthday which is Aug. 1st. I measured the front and it is so close to being square, that I don't think I could get it any better. Now the hood closes real nice and the latch is center.
Check out Patches
Old 06-09-2014, 10:34 PM   #1856
Xeen
Xeen's Avatar
Re: 1968
Great George it sounds like you are making progress.
You are so close man the end is in sight, onward and forward!
Old 06-12-2014, 10:08 PM   #1857
gdavis
gdavis's Avatar
Re: 1968
today I cleaned up some parts and cleaned up the shop some. it always seams to get dirty without even trying.
Check out Patches
Old 06-13-2014, 08:10 PM   #1858
Mustard72
Mustard72's Avatar
Re: 1968
Glad to hear about your hood, George. Can't wait to get to that point with mine, but that's a long ways off.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 06-14-2014, 12:00 AM   #1859
gdavis
gdavis's Avatar
Re: 1968
I remember when I said the same thing. You will be there before you know it. Just keep stabbing and I did notice that you done a little more of the body work. george
Check out Patches
Old 06-14-2014, 12:06 AM   #1860
gdavis
gdavis's Avatar
Re: 1968
Today I adjusted the left head light. It was a little off. I now think that I will make the gasket for the door handle. Got what I need to do it. I just couldn't pay what they are wanting for a simple gasket. Has anyone seen a distributor cover? It is made out of steel and is chromed. I saw one in a corvette in a auction and I like the way it looks.
Just a thought anyway. It might be home made.
Check out Patches
Old 06-14-2014, 09:24 PM   #1861
gdavis
gdavis's Avatar
Re: 1968
I had to take a break from the truck. My pump went out in my fish pond. so I have been working on it. My wife thinks I have too many thing going on. I am about to agree with her. still debating on if I need to keep the pond and spend a lot of time working on it. I might even let it grow natural. it would save a lot of money. 200.00 for another pump.
Check out Patches
Old 06-16-2014, 02:27 AM   #1862
gdavis
gdavis's Avatar
Re: 1968
HAPPY FATHERS DAY GUYS. had dinner with two of my kids today. Was really nice.
Check out Patches
Old 06-17-2014, 12:11 AM   #1863
gdavis
gdavis's Avatar
Re: 1968
Nothing again today. It was raining and it's hard to get motivated.
Check out Patches
Old 06-17-2014, 12:26 AM   #1864
Xeen
Xeen's Avatar
Re: 1968
LOL George trust me I know about the whole lack of motivation thing but don't even worry about it you will get it done soon enough.
Just think about it, you are so close now just a few more steps and you will cross the finish line!
Old 06-17-2014, 11:30 PM   #1865
gdavis
gdavis's Avatar
Re: 1968
Yea I am. I just have so many thing going on that it just seams that I don't have time for the truck. I went to the insurance office today to look over my insurance policy on the truck. I thought I better have a look see. Well I am glad I did. It wasn't covered for anything. Now I have to take it down to the insurance office and they have to take pictures of the truck. But, they want take the pictures until I get the wind shield in and the bumpers on the truck. So, here I set with my truck un- insured. Not like I haven't been doing it anyway. So this month I want to get those parts installed. Then I will trailer it down and take the pictures. They didn't say it had to run.
Check out Patches
Old 06-17-2014, 11:56 PM   #1866
Mustard72
Mustard72's Avatar
Re: 1968
Hey, you could ride in the truck on the trailer and pretend you're driving.
BTW, happy belated Fathers Day to you, too .
Nick
Old 06-18-2014, 01:26 AM   #1867
Xeen
Xeen's Avatar
Re: 1968
George how is the rebuild going on the edelbrock carb?
Old 06-19-2014, 12:16 AM   #1868
gdavis
gdavis's Avatar
Re: 1968
hey that is a good idea. I might try that. better yet I better not. Jonny law would love that. Me riding on a trailer.
Check out Patches
Old 06-19-2014, 12:18 AM   #1869
gdavis
gdavis's Avatar
Re: 1968
I did not get that carb. I was to late and it was already sold. still looking for another one.
Check out Patches
Old 06-20-2014, 10:06 PM   #1870
gdavis
gdavis's Avatar
Re: 1968
Today, I located my speedometer cable. I cleaned it up and painted I and mounted it back on the truck. Then I started to build some flat shims, that goes behind the hinges.
Up till now every thing was mounting great. Except the right side door(pass side). There is a 1/2 inch gap that can not be adjusted out. So, it finally caught up with me on the (not welding braces inside of the cab). Everyone warned me, but then it was too late.
No having experience in doing this kind of a job, well I have to deal with it now. The only way I see out of this is divide the space between the hinge side and the latch side. So I will be putting a 1/8 inch think plate behind the hinge so that it will shift the door towards the latch side. If this makes since. I can't see any other way to solve this except for taking the rockers off and doing a lot of cutting and welding and grinding. That is not going to happen.
Any other way please tell me. I will post before and after pictures tomorrow maybe.
Check out Patches
Old 06-20-2014, 11:25 PM   #1871
Xeen
Xeen's Avatar
Re: 1968
George measure both doors and make sure they are the same dimensions from front to back because it's possible you got a hold of a door that has been lengthened or shortened in the past, if they are the same then measure the gap between the A-pillar and B-pillar at the top and bottom on both sides, you just need to do a little bit of trouble shooting to figure out where the problem actually is so you know what your options are.
Old 06-21-2014, 10:37 PM   #1872
gdavis
gdavis's Avatar
Re: 1968
Yea I measured them a while back and the opening on the right side is 1/4 wider than the left side. I did not measure the doors I guess I will do that tomorrow or Monday thanks for suggesting that. The doors did come off two different donor trucks.
Check out Patches
Old 06-21-2014, 10:58 PM   #1873
Xeen
Xeen's Avatar
Re: 1968
George 1/4" is nothing I think you can adjust that out by rotating the cab slightly to compensate.
No one will be able to tell the difference.
Old 06-22-2014, 07:40 PM   #1874
gdavis
gdavis's Avatar
Re: 1968
I measured the door today. one is 39 3/8 drivers side and the pass side is 39 3/8. But the openings are a lot different. Left side is 38 3/4 and the right side is 39 3/8 that's 1 3/8 difference from one side to another. That's the same side I replaced the pillows on. I guess I didn't weld the pillows in the right place. or measurements. so now I guess I will try with the spacers on the hinges. See if that works.
Check out Patches
Old 06-23-2014, 06:27 AM   #1875
Xeen
Xeen's Avatar
Re: 1968
Wow George that's a pretty big difference between the two sides, it's no wonder you are having serious gap issues. What I can't figure out is how two identical rockers fit on both sides without modifications on one side or the other if you have that much of a difference in length. I'm completely baffled did you have to section one of the rockers and lengthen or shorten it?
