Old 06-10-2014, 02:34 PM   #201
ZouchaR
Re: My 63 Project
So it looks like mine is already tapped.
ZouchaR is offline   Reply With Quote
Old 06-10-2014, 02:35 PM   #202
1963c-10
1963c-10's Avatar
Re: My 63 Project
Yup....that's it. So jus get the stud an insert it and your in business.
1964 Short bed trailer
Old 06-10-2014, 04:18 PM   #203
McMurphy
McMurphy's Avatar
Re: My 63 Project
Well yes, maybe.....
When I dropped my engine in, the mounting spot for the pivot ball on the block was nowhere near where the throwout arm needed it to be.
I had to make this small adaptation to get mine to work:
This was all on page 24 of my build if you need to take a look at it....
Name:  07oct12 tranny (4).jpg
Name:  07oct12 tranny (6).jpg
Name:  07oct12 tranny (7).jpg
Name:  08oct12 clutch linkage (4).jpg
Good luck, hope it all lines up for you
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 06-25-2014, 07:51 PM   #204
ZouchaR
Re: My 63 Project
Just a quick video to show today's progress...
https://www.youtube.com/watch?v=OUQB...ature=youtu.be
Old 06-25-2014, 11:10 PM   #205
ZouchaR
Re: My 63 Project
It fits!!!
Old 06-25-2014, 11:12 PM   #206
ZouchaR
Re: My 63 Project
So the weight of the motor has squatted the front end down pretty low. I may have to go back to full springs.
Old 06-25-2014, 11:15 PM   #207
ZouchaR
Re: My 63 Project
I measured the lower control arm, 4 inches off the ground.
Tomorrow, getting the doors and windows back together.
Old 08-28-2014, 11:01 AM   #208
ZouchaR
Re: My 63 Project
So very typical, when you have the time, no money, when you have the money, no time.
On top of that, it's just been so dang hot to work. But, I got some jewelry in.
Old 08-28-2014, 11:10 AM   #209
ZouchaR
Re: My 63 Project
Not too bad to install. Much only question, the horizontal weather strip at the bottom of the window, does that go on the outside of the strip on the back of the door??
Old 08-28-2014, 11:11 AM   #210
ZouchaR
Re: My 63 Project
And the drivers side.
Old 09-04-2014, 11:00 PM   #211
ZouchaR
Re: My 63 Project
So I ordered this serpentine setup today. Should look good.
Old 09-09-2014, 12:06 AM   #212
ZouchaR
Re: My 63 Project
Transmission cross member being mocked in. Going to have to do some adjusting though as the shifter linkages might hit the cross member.
Old 09-09-2014, 12:10 AM   #213
ZouchaR
Re: My 63 Project
Time to fix this hole in the cowl where the spotlight came through.
Old 09-09-2014, 12:11 AM   #214
ZouchaR
Re: My 63 Project
Getting the plug in was a challenge.
Old 09-09-2014, 12:12 AM   #215
ZouchaR
Re: My 63 Project
Weld it up, grind it, and then some filler. Should be good when I am done.
Old 09-12-2014, 12:40 AM   #216
ZouchaR
Re: My 63 Project
Workin on the gas tank today.
Old 09-29-2014, 05:28 PM   #217
ZouchaR
Re: My 63 Project
Little bit of color on the calipers.
Old 09-29-2014, 05:29 PM   #218
ZouchaR
Re: My 63 Project
And the calipers back on.
Old 09-29-2014, 05:32 PM   #219
ZouchaR
Re: My 63 Project
This should look good!!
Old 09-29-2014, 05:35 PM   #220
ZouchaR
Re: My 63 Project
Small problem with one of the mounting holes on the power steering pump or this job would be done.
Old 09-29-2014, 05:36 PM   #221
ZouchaR
Re: My 63 Project
Better picture.
Old 09-30-2014, 01:49 AM   #222
ZouchaR
Re: My 63 Project
LED.turn signals. The chrome cleaned up very nice.
Old 09-30-2014, 01:50 AM   #223
ZouchaR
Re: My 63 Project
Headlight beauty rings. Before and after.
Old 09-30-2014, 01:51 AM   #224
ZouchaR
Re: My 63 Project
The rings had been painted black and then silver. But they cleaned up.
Old 09-30-2014, 08:32 AM   #225
1963c-10
1963c-10's Avatar
Re: My 63 Project
Are the headlight bezels steel or aluminum? They cleaned up nicely!!!
Vent assemblies look great also. Who did you order them from?
