upgrading brakes
I'm putting disk brakes in the rear of my 71 c10.
do i have to replace the master cylinder to a different one or will the stock one work?
Jared 2014 Ram 2500 powerwagon 2006 GSXR 600 2012 Arcticcat proclimb 800 1970 C10 SWB 5.3LS turbo and 4L60E ![]() ![]() "all throttle no bottle" "Nitrous is like a hot chick with an STD, you wana hit it but afraid of the consequences" "its not turbo lag, its for play" |
Old Skool Club
![]() Join Date: Jun 2001
Re: upgrading brakes
Good question. There are vendors who will happily let you know for sure. I think the amount of fluid needed for discs is less than for drums, but I believe the bigger issue is the balance of pressures between front and rear, needed for proper stopping.
SSBC has a website that may be of some help. Also, the other forums on this site may be a resource to use.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
i'm sure someone will correct me if i am wrong, but I think you'll just need to switch the proportioning valve under the mc from disc/drum model to a disc/disc model.
-Ed |
Ok thank you for your help.
Regarding the proportioning valve, it depends on whether you are getting calipers with integrated parking brakes (El Dorado rear calipers). Without the parking brake, the disc/disc valve would be fine since you don't need a residual valve. The El Dorado calipers require a residual valve to counter act the parking brake spring to prevent the piston from moving too far out. The disk/drum proportioning valve has the residual valve built in for the rear circuit.
