Old 06-11-2014, 07:02 PM   #1
64chevmn
New cab bushings---do I have them correct?
I found a picture in my assembly manual on how I think the new cab bushings need to be installed. Can someone take a look at the pictures and see if I have the washers/spacers/rubbers in the right order. I received three sizes of washers and two sizes of bolts.......trying to make sure I have the bolts and washers in the correct (front compared to rear) location. Here is a picture of the front cab mount with the larger bolt and the largest washer on the very bottom?
64chevmn is offline   Reply With Quote
Old 06-11-2014, 07:04 PM   #2
64chevmn
Re: New cab bushings---do I have then correct?
Here is the rear bushing with the smaller diameter bolt?
Old 06-11-2014, 09:33 PM   #3
1963c-10
1963c-10's Avatar
Re: New cab bushings---do I have them correct?
smaller bolts go to the rear. you have the mounts in the correct order, but the largest washer goes on the largest mount. looks like you have the largest washer on the rear top. should be largest washer on the front top with the mount you have there.
1964 Short bed trailer
Old 06-11-2014, 09:35 PM   #4
1963c-10
1963c-10's Avatar
two largest mounts and washers - top front
two med mounts and washers - bottom front
two med mounts and washers - top back
two smallest mounts and washers - bottom back
also...two longer sleeves go up front and shorter ones in the rear
Old 06-12-2014, 10:05 AM   #5
64chevmn
Perfect.........Thanks guys!
Old 06-12-2014, 02:02 PM   #6
old cool
I needed to squirt a little lithium between washer and rubber a few years after mounts were installed.. It eliminated a annoying squeak. Not sure if that's recommended??
Can anyone say how much squish there should be when tightening new mounts? This thread could be related to my thread regarding a popping noise I get in rear when cornering. Maybe a couple more spins on the bolts would eliminate the pop??? My thread is "leaf spring bushings and popping noise".
old cool is offline   Reply With Quote
Old 10-29-2014, 01:50 PM   #7
ChevyJr
ChevyJr's Avatar
64chevmn - What brand of cab mounts did you purchase?
ChevyJr is offline   Reply With Quote
Old 10-29-2014, 05:18 PM   #8
butch2000
nice finish on the frame ? what did you use ?
butch2000 is offline   Reply With Quote
Old 03-29-2016, 01:23 PM   #9
CRGRS 66
CRGRS 66's Avatar
When I tore my truck down I didn't know that I needed to save the shim/factory washer for the front mount. Could anyone possibly give me dimensions for this item? It is number 14 on the assembly instructions, also referred to as the Factory Washer I prothane cab mount kit instructions. Mainly I am wanting to get the thickness cirrect.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 03-29-2016, 01:35 PM   #10
CRGRS 66
CRGRS 66's Avatar
One other question...
Th little tube of lubricant that came with the kit, there isn't much of it.
Is there just somewhere specific, there is no reference to the lubricant in the assembly instructions that came with the kit. I am wondering, should get some more lubricant and be liberal with it to prevent any squeaks in the future????
Craigerrr
Old 03-29-2016, 02:45 PM   #11
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I would be careful over lubing the rubber might breakdown faster.
Old 03-29-2016, 03:04 PM   #12
CRGRS 66
CRGRS 66's Avatar
thanks for posting aerotruk
I have the urethane kit, and would use a lubricant that would not interact with this material...,
more interested for now in the factory washer dimensions.
Craigerrr
Old 03-30-2016, 09:36 AM   #13
Matt58
In the top pic isnt the top bushing upside down? I thought the sleeve protruding from the bushing went down into the hole in the frame/mount.
Matt58 is offline   Reply With Quote
Old 03-30-2016, 11:47 AM   #14
CRGRS 66
CRGRS 66's Avatar
Thank you for posting, I believe you are correct.
1963C10 also notes the other corrections to the photos posted by the OP.
I am hoping someone will chime in on the "factory washer"...
Craigerrr
Old 03-30-2016, 12:51 PM   #15
ptc
ptc's Avatar
The lube is for the sleeve, going into the bushing.... just a tiny bit to keep it from 'welding' itself in there over the years is all you need.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-30-2016, 01:12 PM   #16
CRGRS 66
CRGRS 66's Avatar
Thanks appreciate the input ptc, good to know, also explains why there is such a small amount of the lubricant.
Only question I have now is regarding the dimensions on the "factory washer" for the front mount that apparently goes between the top bushing and the cab.
Craigerrr
Old 03-30-2016, 01:29 PM   #17
jtrichard
Shim as needed for sheet-metal alignment.... If you have the front sheet metal still on then you can shim now if you have just the cab then snug the bolts and shim when you install fenders ECT.
jtrichard is offline   Reply With Quote
Old 03-31-2016, 02:57 AM   #18
lower50's
lower50's's Avatar
I've had polly bushings on my jeep for years with no trouble. It does not mater how much grease you use just use a lithium based grease or a synthetic water resistant marine-grade grease. This type will not harm the bushings. Petroleum based greases will actually eat the bushing away. Done that.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-31-2016, 08:00 AM   #19
patrickk1
I just buy a bunch of giant washers from the hardware store and shim the mounts from there. I do not think there is anything special about the factory one.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
Old 03-31-2016, 02:47 PM   #20
CRGRS 66
CRGRS 66's Avatar
Thanks to all who posted, appreciate the input!
Craigerrr
