Old 06-12-2014, 10:46 AM   #1
Cteufert
Cteufert's Avatar
65 C20 Notch Install -- 30+ rivets to remove
After doing some research and making some phone calls I decided to install the Porterbuilt front and rear kits. Everyone I asked said both should fit. The front went in quick and easy. The rear on the other hand is fighting the whole way.
Seems there may be two different C20 frame styles, my has a reinforcement inside the frame from just before to just after the axle along with an extra cross member. Both have to removed to install the bolt in frame notch kit. I checked another C20 and doesn't have either so it probably identical to a C10. I stopped counting the rivets needing to be removed once I hit 30 and there were still more.
The larger rear end also prevents the lower shock cross bar from fitting. It contacts the bottom of the rear. A pair of 1" lowering blocks will help but with the Porterbuilt brackets under the u-bolt already there is not enough thread left on the u-bolts. Will have to shave the lowering blocks down to 3/4" and bend the lower shock mount bar a little more.
See what I park on the other side of the garage http://www.57camaro.com
Cteufert is offline   Reply With Quote
Old 06-12-2014, 10:54 AM   #2
1963c-10
1963c-10's Avatar
Re: 65 C20 Notch Install -- 30+ rivets to remove
You have to love grinding rivets....done my share of them.
1964 Short bed trailer
Old 06-12-2014, 10:59 AM   #3
wayno
Get low get low get low
Just when I thought I had them all - I went to put the front sway bar on and realized I needed to can two more... enjoy!
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 06-12-2014, 12:10 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
There's a much better way, but you'll need a torch and an air chisel.
Heat the rivet head until it's cherry red. Don't hit the trigger and blow the head off. Instead, get the air chisel with a flat chisel bit and shear the rivet head off flush to the frame. Get the torch and heat the stem of the rivet. Don't hit the trigger, just heat the stem. Then, change out the flat chisel bit to a center punch bit and drive the rest of the rivet out. The holes will come out perfect each time, and you won't have to spend hours grinding rivets and trying to drive out a rivet without the aid of heat.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 06-12-2014, 01:23 PM   #5
1963c-10
1963c-10's Avatar
I agree...but no torch here. If I had one though...its the method I'd go with.
Old 06-13-2014, 02:37 AM   #6
natecr
I just did a notch on my 66 c20 its a pita!!!! But i converted to a 5lug 12 bolt so i had no other clearance issues
66' custom camper 327/3spd 3.5/5 drop 17"s
2013 Subaru STI stage 1, exhaust, springs, sways ect
2002 mustang Gt. Paxton novi 2000, caged, tubular everything, 441/409 hp/tq too much to list.
1994 dodge cummins, straight piped, nv4500 swapped/built too much to list.
natecr is offline   Reply With Quote
Old 06-13-2014, 06:08 PM   #7
Snailed
Snailed's Avatar
You can just use an air chisel without heat as long as it has a little power. It's a 30 second affair once you do a couple.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
