Old 01-04-2004, 03:20 PM   #1
duke68ss
Angry 5 lug conversion ??
All you guys that have converted over to 5 lug from a 6 lug... how was it for you guys? I want to convert really bad but like all things time and money is an issue.. Any cheap but quality kits? I have no clue what I'm about to get into so help me out guys! :burnout:
duke68ss is offline   Reply With Quote
Old 01-04-2004, 03:45 PM   #2
Rooster's 67
Rooster's 67's Avatar
Re: 5 lug conversion ??
Uh.....those two things dont go together.....at all
try picking up the parts you will need over a period of time.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-04-2004, 04:00 PM   #3
jmanz69
Careful, they attack...
jmanz69's Avatar
Like rooster said. Get the parts over time. You can usually find someone with a set of disk spindles for sale. Then get all new brake parts. With the rear, you could just have your 6 lug rear redrilled at a machine shop or fabrication shop. Would be cheaper than getting a new rear end. Take your time, it's gonna get $$ if you're not careful. You could buy a kit from any of the vendors here, I hear they are all really good. Most even use your existing parts.
Good luck.
jmanz69 is offline   Reply With Quote
Old 01-08-2004, 10:23 PM   #4
Quagmire
A splendid one to behold
Quagmire's Avatar
maybe a little OT, but are there any 5 lug axles you can swap out versus having them drilled?
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 01-08-2004, 10:46 PM   #5
1972C10
1972C10's Avatar
Depending On what year The Rearend is Some 5 Lugs Will Go In I did one not sure of the year i think the rear was out of a 69 or 70 they went right in ..
A friend of mine and myself did a 5 lug conversion put 72 spindles on his 68 and we were goin to swap axles but his was shorter by half an inch of so If getting 6 lugs redilled is pricy you could always get some 5 lugs cut down and resplined
1972C10 is offline   Reply With Quote
Old 01-08-2004, 11:36 PM   #6
Blue Beard
Blue Beard's Avatar
Swap the complete front crossmember would be easier.............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-08-2004, 11:53 PM   #7
gregsplace
gregsplace's Avatar
wouldnt happen to be traveling through Kansas anytime soon? I have disc front ends and 5 lug axles/rearends!
67 3/4 4x4 402,a/t,flat bed
98 GMC Sierra swb daily driver
87 burb parting out.
68 1/2 chevy, 350/350, 71 gmc frame, kid's beater
69 1ton 396-4sp, dump
69 swb stepside 396/400th current frameup
67 swb 454/400th rebuilding now, oldest boy just rolled it
99,HD, Road King Classic
Colwich Ks
gregsplace is offline   Reply With Quote
Old 01-08-2004, 11:58 PM   #8
Randy70C-10
Randy70C-10's Avatar
The cheapest way to do it is to buy a complete rust-bucket beat up non-running truck with a 5 lug suspension and swap everything over.
Randy70C-10 is offline   Reply With Quote
Old 01-09-2004, 12:08 AM   #9
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
why not just convert the front to 6 lug discs, lots of good kits for that and plenty of nice wheels nowa days?
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 01-09-2004, 01:58 AM   #10
Quagmire
Quagmire's Avatar
how much?
cheapest or the easiest?
67 swb
02 wrx
Old 01-09-2004, 05:48 AM   #11
1972C10
1972C10's Avatar
O yeah the brake line on drums are in the rear and there in the front on disc my friend used the stock drum line and screwed it into the disc caliper it doesnt have a banjo fittin but it still works fine no problems. and the upper ball joints are different you will have to get 71/72 ball joints for the top the bottom is the same. other than that its a breeze putting in 7172 spindles.
Old 01-09-2004, 07:04 AM   #12
bigfredtn
Active Member
Location: West TN (Memphis area) now. East TN (my favorite place to live).
Find a 73 to 78 chevy truck and get the complete crossmember. Should bolt right up with a little modification.
BigFredTN
70 chevy stepside 350 with some goodies inside, turbo 400.
69 Chevy long wheel base. Dad bought new in 1970
62 Chevy Impala
98 GMC Yukon
1970 Ford Mustang Fastback I know its a Ford.
bigfredtn is offline   Reply With Quote
Old 01-09-2004, 09:33 AM   #13
SCOTI
SCOTI's Avatar
The fronts are like everyone has listed. Find a 71-2 or the more available 73-up front spindle assembly (shouldn't break the bank here).
The rears have several options:
1) Swap rear ends. IMO thats going to cost some $, + the downtime to complete the swap.
2) Re-drill your current axles to 5-lug. That's going to also be $, + downtime for the machining (can't drive the truck w/o axles), + time for R&R.
3) Replacement axles/drums. More $$, but if you analyze the cost, it's an easy choice. Replacement axles can be ordered from several sources & have the benefits of having zero wear @ the bearing races (common prob w/30yr old factory axles) + they typically are around 30% stronger than factory axles. You get to drive the truck while waiting for your axles to arrive & the only downtime is the R&R.
'Cheap' doesn't always mean less cost when looking @ all variables. Time spent rounding up parts, machining, & R&R should all be considered.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-09-2004, 11:38 AM   #14
swdobbs
5 lug swap
I purchased a 1983 2wd front end from a rearended truck, crossmember a-arms ps box etc... It cost me $200 (could have done better) and then had a local hot rodder install it for another $200. It beat any kit I came across, came with better springs,the ball joints had been replaced and got me ps.
The chassis shop had to drill 2 new holes, and slot 2 others, he was sceptical but it was only 4 hours total.
swdobbs
swdobbs is offline   Reply With Quote
Old 01-09-2004, 12:30 PM   #15
Randy70C-10
Originally posted by Quagmire
how much?
I can buy trucks all day long for a less than $200. Try buying those parts for less than that.
Old 01-09-2004, 03:06 PM   #16
Quagmire
Quagmire's Avatar
good info, thx guys
any benefits to running a 71/72 setup vs. something 5 or 10 years newer or vice versa?
67 swb
02 wrx
Old 01-09-2004, 03:41 PM   #17
SCOTI
SCOTI's Avatar
The 71-2 stuff requires a different draglink that's potentially harder to find vs. 73-up models.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
