Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-14-2014, 09:43 PM   #1
crewcabshorty
crewcabshorty's Avatar
wtb helper spring brackets
my 1 ton crew did not come from the factory with helper springs. I have located everything, new springs, perches w/plastic sleeves , spacers , and the top pieces. the parts that I still need are the reinforcement brackets that connect the spring perches to the frame . thanks for the help.
crewcabshorty is offline   Reply With Quote
Old 06-15-2014, 03:12 PM   #2
SCOTI
SCOTI's Avatar
Re: wtb helper spring brackets
I can look through my removed parts from my CC dually. If I understand correctly, you're looking for the brackets that triangulated/gusset the rear spring perches to the horizontal part of the frame?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-15-2014, 09:28 PM   #3
crewcabshorty
Yes , thats correct . they are the horizontal brackets that were riveted to the spring perches front and rear . thanks
Old 06-16-2014, 11:38 AM   #4
SCOTI
SCOTI's Avatar
Ok. I'll check this afternoon & make sure I still have them. I'll follow-up this evening....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-20-2014, 11:02 PM   #5
SCOTI
SCOTI's Avatar
The overload-spring brackets I cut off my frame did not have reinforcement brackets (they were just riveted to the side of the frame).
The rear leaf spring hanger did have a reinforcement bracket that was rivited to the bottom of the frame & gusseted the hanger where the bolt went through.
Are these what you need? These reinforcement brackets were only attached @ the rear/bottom of the frame. The front hangers did not have any additional gussets/brackets on my dually.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
