Old 06-12-2014, 02:10 PM   #326
Hart_Rod
Hart_Rod's Avatar
Re: '72 Drop member... "Betty"
Clean.
Hart_Rod is offline   Reply With Quote
Old 06-12-2014, 02:20 PM   #327
Rochlow
Originally Posted by olrosa View Post
Drive line in. 2" spacer on carrier bearing
Would you happen to know the outside diameter of these spacers?
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 06-12-2014, 04:13 PM   #328
olrosa
olrosa's Avatar
I believe 1 1/2"
olrosa is offline   Reply With Quote
Old 06-15-2014, 12:02 AM   #329
olrosa
olrosa's Avatar
Exhaust system. Going to take it apart and paint black
Old 06-15-2014, 12:43 PM   #330
olrosa
olrosa's Avatar
Bed wood almost in. We cleared and sanded this stuff like 10 times. Next time my process will be different. Man these kicked my butt
Old 06-15-2014, 04:03 PM   #331
knomadd
knomadd's Avatar
Looks good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 06-15-2014, 07:52 PM   #332
jlaird
jlaird's Avatar
Really nice stuff going on. The diff vent is very cool. Consider that idea stole! The bed wood looks real nice too. You mentioned doing something different if you were to do it again. What would that be?
jlaird is offline   Reply With Quote
Old 06-15-2014, 10:01 PM   #333
1stchevy
1stchevy's Avatar
Man this is taking shape quick, looks great!
1stchevy is offline   Reply With Quote
Old 06-15-2014, 10:40 PM   #334
Bennett68C10
Bennett68C10's Avatar
Man your exhaust and bed wood look great. Nice job.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-16-2014, 12:21 AM   #335
olrosa
olrosa's Avatar
After I stained them I just started clearing them, sanding in between each heavy coat or 2 but the clear is to hard to get built up thick enough to hide the wood grain. Next time I will coat with a product like "bar top" that flows into all the grain, then clear it for uv protection. I haven't done the 4 corner pieces so I will try it in them and let you know. The first way took me 2 weeks of sanding and clearing. F that!
Old 06-17-2014, 04:47 PM   #336
superflysteiny
superflysteiny's Avatar
I have been through this before. You have to stain them seal them then clear with automotive clear. If you don't seal then the wood will suck up the clear and it will take forever. Ask me how I know this.
superflysteiny is offline   Reply With Quote
Old 06-17-2014, 05:40 PM   #337
olrosa
olrosa's Avatar
Amen brother!
Old 06-17-2014, 11:54 PM   #338
olrosa
olrosa's Avatar
Here is some more progress. Got the sloshtubz installed, the bed on and the accuair mounted and mostly wired. Getting closer. I need it finished for our annual car show at the dealership on the 28th
Old 06-18-2014, 10:37 AM   #339
olrosa
olrosa's Avatar
Ttt
Old 06-18-2014, 11:41 AM   #340
Rochlow
very nice
Old 06-18-2014, 12:40 PM   #341
olrosa
olrosa's Avatar
Originally Posted by knomadd View Post
Looks good!
Thanks fellas, glad you like it.
Old 06-18-2014, 12:42 PM   #342
ebustos
seth when the truck is laid out how close are top of the rear tire to the bottome lip of the bed side. Just wondering how much I have to cut.
ebustos is offline   Reply With Quote
Old 06-18-2014, 12:55 PM   #343
olrosa
olrosa's Avatar
I left about inch of metal below the bed rails so I could bolt my wheel tubz in and it still gave me good clearance. I don't remember exact numbers and I'm at work so I'm away from truck. Hope that helps you
Old 06-18-2014, 02:14 PM   #344
lolife99
67-72 parts collector,…
lolife99's Avatar
Does this picture help?
Keith
Convert to disc brakes.
Old 06-18-2014, 02:56 PM   #345
preacher anthony
What was the wheel sizes again?
preacher anthony is offline   Reply With Quote
Old 06-18-2014, 03:39 PM   #346
Bennett68C10
Truck looks awesome
Keith
66 Suburban
IG: bennett68c10
Old 06-18-2014, 04:02 PM   #347
olrosa
olrosa's Avatar
5.5 front 5.75 rear. I have the wider factory rear end still.[/QUOTE]
22's
Old 06-19-2014, 01:43 PM   #348
olrosa
olrosa's Avatar
Couple more shots. Painted exhaust ceramic black and we were able to get the stock brake booster to fit with sloshtubz. I was happy about that because I want to keep the stock ish appearance.
Old 06-19-2014, 01:45 PM   #349
mikeleeshields
mikeleeshields's Avatar
It looks great Seth. I am about to run exhaust also.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 06-19-2014, 01:56 PM   #350
jlaird
jlaird's Avatar
Thanks for that info! Can u give us an example of the particular sealer to be used?
The exhaust came out great. What ceramic black paint did you use?
