![]() Join Date: Jun 2011
quadra jet ID help
Im going to rebuild my Quarda Jet and the ID is missing. Anybody know what I have?
Re: quadra jet ID help
Best way is to clean it up some and read the numbers that should be there.
http://www.cliffshighperformance.com...carb_ID_2.html http://www.digitalcorvettes.com/foru...79&postcount=2 For tuning and troubleshooting information I'd suggest reading the entire thread. http://www.digitalcorvettes.com/foru...t.php?p=975879
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Look on the drivers side, near the rear of the carb. You should see numbers stamped right in the carb body.
Most of the kits out there cover a number of carbs. I went with a NAPA kit and float. Was about $45 for both. Here are the part numbers: CRB 25784 - Carb kit CRB 2467 - Brass float |
thanks for the help guys.
![]() Join Date: Dec 2007
Check out you tube as well. Many fixes and tweaks for what is a really good spread bore after said fixes are done..... an often misunderstood carb.
