06-14-2014, 06:09 PM | #1 |
rear brake drum stuck
Well it moves a little...lol. tapped with hammer and lubed. The e brake cable broke but I can pull and push cable with no help. Any suggestions?
06-14-2014, 06:13 PM | #2 |
Robert Olson Transport
Re: rear brake drum stuck
bigger hammer and also you can try to get a screwdriver into the hole on the back to move the adjuster lever and adjuster
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
06-15-2014, 09:42 AM | #3 |
Our high school shop teacher said to just get a bigger hammer. It will either come off or break. I seem to remember carefully grinding the heads off the pins once to remove some drum brakes.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-15-2014, 01:25 PM | #4 |
Like old Rusty said...screwdriver through the backing plate slot, and back off with the adjuster.
06-15-2014, 04:51 PM | #5 |
Try the backing plate if you can, but even if you smash it off with a sledge you aren't very likely to break anything that costs more than a few dollars.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually 1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr 1991 CR500 (95 Burb wouldn't stop catching fire ) |
06-15-2014, 04:58 PM | #6 |
if its really stuck good, big hammer and a sharp chisel and crack it, drums are cheap.
06-15-2014, 07:49 PM | #7 |
Back off the adjuster and spray some Kroil,PB blaster, etc at center of drum where it slides over axle.
It is more than likely hanging on the shoes. The shoes wear a groove in the drum over time and you have to back way off on the adjuster for the drum to clear the shoes. |
06-16-2014, 08:35 AM | #8 |
78K & 79C Jimmys
back it off and 5 lbs sledge,hitting it up, down,left, right
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
