Wood bed
Im going to be redoing the wood bed on my 1967 c10 and the wood is to rotted to know what the measurements are of it and was just wondering what they are
Re: Wood bed
Here are a couple links that will give you everything you need to know.
http://www.mar-k.com/Catalog/PDF/Ins...Dimensions.pdf http://www.gmcpauls.com/47-72_BedWood_Info.htm
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
CAN'T FIX NOTHIN
Re: Wood bed
Hello I dont know the measurements but go to MAR - K S website and you can buy the wood already cut , can you post some pics of your truck ?
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Re: Wood bed
the links are perfect thank you alot and ill post some tomorrow its night now
Re: Wood bed
Heres the bed
Re: Wood bed
that salt is sure tough on these trucks up there. You all have had a brutal winter.
Figure out what you want--then figure out what you are willing to give up to get it. |
![]() Join Date: Jan 2014
Re: Wood bed
Ahhhh that's not so bad.
Re: Wood bed
Ya there is way to much salt up here it ruins the classics and the cab mounts are still good just the bed mount is bad so i just might pull the bed off and run it just frame for the summer
Re: Wood bed
I remember rust well. Grew up in NW Iowa. Moved to Arizona in '94. Was sporting wood for 2 solid weeks seeing all the unrusted classics! Brought my '76 K5 rustbucket out with me. Locals kept coming up to me wanting to know what happened?!?
Re: Wood bed
Looks alot like mine when i first got it. Just an fyi be ready to replace/repair the cross sills also. Mine were shot. I ended up buying a parts truck and swapping out the bed(steel floor). It was alot cheaper. From the looks of it if you want original you will also need new bed slats to hold the wood down(those were cut up).
I was born and raised in oswego(in auburn now). I still go up that way with my truck(to sweet insprations in fulton on sats). we need more pics of the whole truck!
My build thread!! http://67-72chevytrucks.com/vboard/s...d.php?t=474018 |
Re: Wood bed
I know i gotta replace almost the whole bed pretty much all the slats are shot wheel wells and inner sides are wicked bad and i just might have to swing over there sometime and check yours out
Re: Wood bed
And ill throw up pics as soon as we get some more nicer weather.
Re: Wood bed
where do we drill the holes in the wood boards? because i have the strip and bolt kit i just need the wood and everyone is telling me its not pre drilled
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
#14 | |
Re: Wood bed
If you've already got the crossmembers from the wood bed you can just drill up the eight holes you need. Loosely get everything in position before you drill. |
#15 |
Re: Wood bed
well thats is the problem lol when i got my truck the wood floor was gone so was the cross sections so i have just a bed box
#16 |
Re: Wood bed
Ha Well then you're on your own!
I guess you just need to get the right crossmembers. |
#17 |
Re: Wood bed
lol i know that is what i am worried about because i dont want it to look incorrect ya know
#18 |
Re: Wood bed
i ordered me some wood from robert noe and its red oak pre cut and grooved and everything any tips on sealing the wood?
#19 |
![]() Join Date: Sep 2010
Re: Wood bed
My 70 C-10's original bed was in bad shape too. It needed all new cross members and a front bed panel. The new wood is red oak with two coats of dark walnut stain to bring out the grain. Finished with five coats of Marine Spar Varnish. The cross members were attached to the frame from underneath. . . . . |
#20 |
![]() Join Date: Feb 2001
Re: Wood bed
WOW ... your bed looked like my bed except I had a metal floor.
The good news its a lot easier to fix the wooded floors. ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#21 | |
![]() Join Date: May 2010
Re: Wood bed
