06-12-2014, 03:13 PM | #1 |
Driveline geometry help...
I have the engine installed using CPPs tubular motor mounts and a crossmember from BMR Hot Rods on the 4L60E trans. Right now, the driveline angle is -9 degrees. From what Ive ready, I want to be somewhere between -3 and -5 degrees. Any thoughts on options? I was thinking of just adding a metal shim to two to the poly mount on the crossmember to raise the tail end of the transmission up a bit as theres plenty of room in the tunnel. Any input would be greatly appreciated.
Thanks! |
06-12-2014, 03:31 PM | #2 |
Re: Driveline geometry help...
Where is the rear end sitting now 2-3 or 4* up?
From what I have read should be +/- 1* difference, shims under the rear mount should work
06-13-2014, 12:23 AM | #3 |
meowMEOWmeowMEOW
Where are you measuring from? -9 down would be kinda steep, you sure you're on a level plane?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
06-16-2014, 06:06 PM | #4 |
Fabricate till you "puke"
2nd that....set the chassis level, then start the read? You should be 3-5 degrees on the engine/trans (closer to 3, if you can) read the rest of the angles, from there.... Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... Last edited by crazy longhorn; 06-16-2014 at 06:07 PM. Reason: spelling |
06-16-2014, 07:09 PM | #5 |
The truck is sitting on the concrete slab in the garage, which I checked with a 3' level and is almost dead on. I used one of those dial indicators and set it on the top of the intake manifold (without the carb installed obviously) and got -9 degrees. The only thing that I can think of is that those tubular CPP mounts sit a little higher than the factory pieces? That being said, the front is riding a bit high as the weight savings from the aluminum LS motor replacing the iron big block. I suppose the best way to do this is to level the truck on jack stands on the frame, and measure from there, that way you take the suspension out of the equation?
Thanks for the input! |
06-17-2014, 12:33 AM | #6 | |
meowMEOWmeowMEOW
Level it on stands, then try your measurement from the manifold again. I did it off the valley, but as long as the intake is square/level, it should be ok to measure from there.
06-17-2014, 11:22 AM | #7 |
yeah man 9* is a lot. the engine perches would have to be raised like ~2" by my math to get to there from stock
