Old 06-17-2014, 03:28 PM   #1
70.2500.Dana.Coil
Question Parts Needed for '70 GMC 2500 P/U W/dana 60 and Coil Springs
[COLOR="Blue"][B]Hi folks, a newbie, here.
I am needing the Automatic Adjuster Lever and Tip for a 1970 Rear Brake that apparently only fits the Dana 60, Coil Spring, C20 & 2500 3/4 Ton Trucks with 12 Inch Brakes.
I need the Passenger (Right) side the Tip that rides on the Star Wheel that is missing and the Lever (Arm) that it connects to looks broken on the end.
Please help if you have, or know where to get these pieces.
I am in the Pacific Northwest, in Washington. Thank you very much, this looks like a Great Forum!
I have found THIS from a Prior post someone else did here, and it says it fits but is not even close for my application. It IS a Left Hand, but the design is wrong as this Lever rides directly on the Starwheel.
http://www.classicparts.com/1964-75-...tinfo/71-661/#
This appears to be NLA at all of the Major Parts Store Websites, if it cannot be found new or Used does anyone know of a Manual Adjustment Kit that includes the course tooth Starwheel, and Contact Spring etc. to convert BOTH Rear wheels to Manual.
70.2500.Dana.Coil is offline   Reply With Quote
