#51 |
![]() Join Date: Oct 2013
Re: 71lsx-LWB**Build Thread**
Really sweet truck ya have there! hows it been running lately? what was the part# on the clutch kit your running? hydro or mechanical throwout bearing? which shifter cleared your seat? I'm also putting a 4 speed (super t10)behind a lq4 in a c20 and its great to hear what worked for the rest of you.
Kale |
#52 |
Man your build is just too cool. I'm tagging a long.
#53 | |
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs) 00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs) |
#54 | |
#55 |
#56 |
here is another little clip, ended up busting the stock 2pc. driveshaft.lol time to upgrade the last piece of the puzzle. it busted at the middle U joint
Any ideas about putting a 1pc driveshaft in long wheel base? or where can i get a strong 2pc ds c10 truck - YouTube
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs) 00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs) Last edited by Benlugchev; 05-13-2014 at 09:59 PM. |
#57 |
Finally put her on the rollers today. It was impressive and scary all at the same time.
I was very happy. Put down 738 RWHP & 700Torque
#58 |
#59 |
#60 |
Yes that was with the Muncie M22. Was at boost at 10psi
#61 |
Very healthy for sure! still running the vinci 218 cam? Planning on doing that 4l80 swap?
#62 | |
I should be picking the 80 up from my tranny guy this week. Time to order up a converter and head back to the dyno for back to back results manual/auto with same tune.
#63 |
Love the truck. I'm from CT too and building a 66 c10.
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
#64 |
Who are you going with for the converter? Circle D and Yank seem to be the go to guys for our kinda stuff, but I'll probably be giving rev max a try when that time comes. They seem to build a really nice (billet) converter that's reasonably priced as well...
#65 | |
#66 |
some street cruising
http://youtu.be/33tf5tV0M7Q
#67 |
Awesome vid. That truck must be a blast to drive!
#68 |
Track pass yesterday ran 4 low 11 sec passes @130mph back to back Best was 11.0@131. Drove the truck 1.5hr to get there. Had issues controlling boost so I ran the lightest wg spring I had (tial's 5lb spring). Boost was all over the place. Time for a second gate and more consistent boost.
Launched on foot brake 2800 rpm @2lbs
#69 |
That must be a fun truck to drive hope mine turns out similar to this and those dyno numbers man very impressive keep up the good work
#70 |
better video with a few clips from the track
http://youtu.be/9Kto_i38r8s
#71 |
#72 |
I was seeing the vids of the white 2500 in the background what are the specs on that if you don't mind me asking I have a 03 4x4 lifted hd on 22x14s and 35s and It's slow I was planning on throwing a turbo on it something simple and reliable any tips and sootyfor the tread hi jack you can pm me if you like.
#73 | |
It's turbo lq4. It went 11.67@116mph. On the Rollers it put out 500/560. I did s475 turbo t-4 housing. Spools fast and it a blast to drive. Put the transgo shift kit in the 80 and make sure you have the full float rear. I built custom "caltrac" type setup device to eliminate any wheel hop and gain some traction works awesome Here is the build for more info http://www.performancetrucks.net/for...0-rclb-508917/
#74 |
#75 |
Re: 71lsx-LWB**Build Thread** New Track Video and results
| Bookmarks |
| Tags |
| 1971 c-10, lsx swap, lwb, muncie, street strip |
