06-15-2014, 09:26 AM | #1 |
Best adjustable stock mount trac bar?
Hello all,
It's been asked before I am sure but I can't seem to find the answer in the search function. I lowered mine 3 inches in the back. It is slightly off side to side by 1/2 inch now in the rear. What or who has the best adjustable trac arm bar available using the stock mount locations out there? Thanks for your help folks.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
06-15-2014, 11:46 AM | #2 |
Re: Best adjustable stock mount trac bar?
Whoever you go with I'd buy a double adjustable bar. Way easier to adjust then the one sided adjustable. As far as stock location I haven't seen one. I think 3-4"+ drop you need to relocate them to the passenger side
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
06-15-2014, 12:28 PM | #3 |
I have dropped mine 4.0 inches. I have a CPP but have relocated it to the lower passenger side. to keep a slight angle to it. They say with 3.0 you don't need it but I have used the same CPP bar in the past located to the passenger side. Fortunately I was able to reuse my stock U Bolts from the factory they came out with out any issues. Yeah I was surprised about it.
If you don't have a rear sway bar it may be a good time to install an IROC bar in there now. Search the site they had a great write up at one time for it and it sits cleaner than any other bar out there. Its no big deal to mount a couple 1.0 spacers, drill 4 holes, 2 3.0 heavy duty U clamps. Mount everything where you want it then tack weld he saddles to the clamps onto the axle tubes. Upgrade the front to the 1.25 front bar from a mid 80's truck it is a complete bolt in. |
06-15-2014, 03:26 PM | #4 |
Cpp has a stock mount adjustable bar for like 55.
E bay also has the same ones
1967custom |
06-15-2014, 04:53 PM | #5 |
Thanks for the sway bar info. I have not done that yet. I'm have to look into the ccp trac bar. Is it double adjustable?
06-15-2014, 08:57 PM | #6 |
I don't believe mine is I would go outside to check but its dark out....and I am afraid of the dark LOL I will check for you later.
06-15-2014, 08:59 PM | #7 |
the article I have is How to Install a Camaro Sway Bar on Your Truck it was a 4 page article
06-15-2014, 10:10 PM | #8 |
Yes, the double adjustable does make it easier. But don't get to hung up, it's really easy to pull one side off to adjust and once it's adjusted you never touch it again.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-15-2014, 10:18 PM | #9 | |
Watch out for your cornhole !
Seems like there's been a lot of focus recently on getting a double adjuster track bar. I do not see the point. Look at it this way, measure your truck to see how far offset the rearend is. Then remove the stock track bar and adjust the new one to length, taking account of the amount of offset you're removing. Then just bolt it on. You'll never adjust it again. It's not something you do repeatedly like changing your oil.
06-16-2014, 02:28 PM | #10 |
I did check on my rear bar. It is a single adjustable one. The only thing I would have done different would be buy one with the bend in it to better clear the rear cover. The straight bar works fine but does limit you on the removal of the rear differential cover.
06-16-2014, 06:13 PM | #11 |
Moderator
x2.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-16-2014, 07:26 PM | #12 |
I just called CPP and Summit Racing and they said that the 6572DATB will fit in the stock location on a truck that is lowered 4" in the rear. The full colasped length is 23" according to CPP.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
06-18-2014, 09:36 PM | #13 |
Cool. Thanks for the info. Since I don't have to much to adjust a single adjustable should work fine. Is it better to go with the relocated style or stock mount style with only a 3-4 inch drop in the rear?
