Old 06-20-2014, 06:08 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Disc Brake swap for a 3/4 and 1 ton
Originally Posted by Purcell69 View Post
Very nice! I purchased a similar kit almost 20 years ago for the 3100 front axle. With the bracket and spacer, I was able to run F-body and G-body rotors and calipers as straight bolt ons, with the passenger car wheel bearings. It worked well.
It's good to see support for the 3/4 ton and 1 ton guys is coming along.
-Joe
3100 kits are all over the place and fairly cheap it would have been nice to get a set and be done with it but our problem was the calipers were to small for a 8800 GVW truck so we couldn't use F body or even C10 or C20 calipers we needed the late model 2500 and up dual piston calipers which are a lot bigger and rated at 8600 GVW. With this bracket its going to be a bolt on kit it just needs some refining in order for it to be a kit that's not to costly.
