Old 06-16-2014, 09:54 AM   #26
Gus350
68 C 10
Gus350's Avatar
Re: Tie Rod Lenths
didn't think about it till now I still have the old tie rods intack ill try to put them on this wekend and see if that lines up better or is the same.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 06-17-2014, 10:09 AM   #27
chevyrestoguy
chevyrestoguy's Avatar
Re: Tie Rod Lenths
I re-read your initial post, and when you say that the tie rod is threaded all the way in, do you mean that the outer tie rod is threaded into the sleeve and it's bottoming out on the inner tie rod inside the sleeve? If so, a shortened sleeve isn't going to help you. You're fighting a tie rod length issue.
If so, then trim the outer tie rod length down 1", re-dress the threads and you'll be fine. Do yourself a favor and before you cut the length, spin the appropriate thead die on to the tie rod a couple of inches. That way, when you turn out the die to de-dress the threads, it'll establish your initial thread groove on the way out. This will make is much, much easier to thread the die back on. After that, spin the die back on and off a couple of times and test it in the sleeve to make sure it'll engage.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 06-17-2014, 11:19 AM   #28
Gus350
68 C 10
Gus350's Avatar
Re: Tie Rod Lenths
Yes that sounds good that will probably be what happens. We were just trying to figure out why everything was to long when all the items are for a 80 model truck is it the modular spindals with the 1 inch forward Porterbuilt arms I do n't know but going to try and figure it out. Thanks for the help.
Kevin.
Kevin
John Wayne
68 C10
70 C20
Old 06-17-2014, 05:35 PM   #29
chevyrestoguy
Re: Tie Rod Lenths
I'm going through the same thing, Kevin. 1964 truck, 1979 suspension, Bell-tech spindles, 1 cut coil, lower control arms moved fwd 1", converted to power steering with an adapter plate, chassis Z'd 2" up. Mines a real Heinz 57.
My build threads:
Old 06-20-2014, 09:22 PM   #30
Andy4639
Old member
Andy4639's Avatar
Question Re: Tie Rod Lenths
Just wondering. Are these the QA1 from Summit?
I just called and asked about them and they said they had none to work on a 71 Chevy C-10. I ended up ordering these.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-20-2014, 09:56 PM   #31
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Tie Rod Lenths
Originally Posted by Andy4639 View Post
Just wondering.
Old Edelbrock/ Now QA-1 Part #5252 will work on the 71-72 truck.
Keith
Convert to disc brakes.
Old 06-21-2014, 08:00 PM   #32
Andy4639
Old member
Andy4639's Avatar
Cool Re: Tie Rod Lenths
Thanks oh well. Live and learn!
