Cool new product - Transparent valve covers
Just read about a cool new product in Classic Trucks magazine. Classic Industries has transparent valve covers and thermostat housings. Kinda pricy though - $289.99 for the valve covers.
http://www.classicindustries.com/197...rts/10110.html
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Re: Cool new product - Transparent valve covers
theyve been around for 40years or so
Apparently they have come up with a new material that doesn't crack or yellow.
![]() Join Date: Apr 2007
Ive never seen these before. Interesting though.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
Those are sweet!
They look cool in the photo, but what's it going to look like after the engine has run for a while?
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
![]() Join Date: Apr 2014
not sure why you need this one but what the hell..
"They Don't write songs about Hondas " 1972 C10 "Ole Red--blood, sweet & beers" USMC 1989-1997 1st Anglico ![]() |
It says that the oil will sheet off within 30 seconds of a full rev. So you can only see thru it at idle.
Who's going to hang off the back of the truck to watch the gears in the rear end while you are driving?
#10 | |
![]() Join Date: Apr 2000
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
![]() Join Date: Aug 2013
Neil............... ![]() 1972 C10 SWB - Shop Truck in the Works 5.3 LS / Full Air Ride / Rear Notch 20" American Racing Daytonas IG - neilioustx - pictures of build/progress Born and Raised in the Promised Land.... TEXAS Y'ALL!! |
I had the different cover on my slammed dodge ram because when it was laid out the rear end stuck up into the bed. I also had a die in it that turned the oil orangeish color. It was cool but I got it for free from a sponsor. I would not have bought it otherwise.
#13 | |
1970 C10 Short Stepper with 71/72 front clip. |
Now on the rear diff I could see it for people like me getting to fat to get under a truck to check the fluid level. As for the v/c and the thermostat housing it is like the new trend for clear upper hoses I just don't get it. I guess I never was cool but then again if that is the standard I don't need to be. Jim
#15 |
Maybe I could see it if you were very very bad at adjusting valves and wanted to look and see what rocker was about to jump off. But if you were smart enough to look and figure that out you could figure out how to adjust the valves maybe?
#16 |
2WD Jimmy
![]() Join Date: Mar 2005
To verify that you indeed blew the gearset. Without having to drop the cover at the track.
#17 |
Old member
I have it on my 71 and think it's like anything else you change. It a personal taste and yes it nice to take a quick look see and say yea it OK!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
