Old 01-10-2004, 02:30 AM   #1
c10rookie
c10rookie's Avatar
tilt swap
Hi guys, could any one shed some light on swapping out my 72c10's stock column for the tilt version from a 79 4x4blazer ?? Also will the rear axle gears & carrier swap to the c10 (both 12 bolt) Thanks Chris
if it aint broke , fix it till it is
355- flat tops - 70cc RPM heads 9.5:1
RPM inlet MSD6 & HEI
headmans & glasspacks
Crane .467/.494 278/290 222/234 114
1.6 roller's 2400 tci 650 Holley
cold air induction electric w/pump,fans,f/pump
c10rookie is offline   Reply With Quote
Old 01-10-2004, 05:28 AM   #2
1972C10
1972C10's Avatar
Yes the gears will swap but there is a difference in carriers say you have 3.08s and you want to put the 3.73s out of the other one in the truck you would have to use the 3.73 carrier but if its 3.08s and you want to put in 3.42s or 2.73s should work fine.
If you have a 3.08 posi chunk that you want to use with factory low gears like me and dont want to locate another chunk just for this Mr Gasket Makes A Ring Gear Spacer That will take Care of that so You can use the Highway Gear Carrier With 3.73 and lower factory gears But they also make aftermarket Low Gears that will work on highway Gear Carriers
I have a 68 that has the newer style tilt in it and it apears to have the same harness for the turn signals if you want to be able to start the truck off the colum you will have to get the ign harness that goes to the tilt and wire it into your ign harness that plugs into the key switch on the dashboard but if your not wanting to use the key on the colum should be a direct plug in on the turn signal if not there are some adaptors to go from a half moon harness to the flat one but im not sure if you will need that
1972C10 is offline   Reply With Quote
Old 01-10-2004, 05:56 AM   #3
Blue Beard
Blue Beard's Avatar
Tilt column from a van would be easier to install and convert. Still using the dash ignition.........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
