Old 06-21-2014, 02:33 PM   #1
tylervalo
Hub or front end issue?
I broke my drive shaft last year and had to drive the truck home on the front wheels in 2 hi. About half way home it started acting like it was popping the TC out of gear.
Today I finally got to drive it again, I took it around the neighborhood in 4 Lo and it started popping again, occasionally acting like it was in neutral for a 1/2 a second. I pulled it in my hard and felt a small pop then nothing, I could see thought he floor the front driveshaft was still spinning but not moving the truck in 4hi or 4lo. I unlocked the hubs, locked the hubs back and hopped back in the truck and it started moving again.
Anyone have a wild guess where my issue might be? I'm thinking something with the hubs.
tylervalo is offline   Reply With Quote
Old 06-21-2014, 02:51 PM   #2
rich weyand
rich weyand's Avatar
Re: Hub or front end issue?
What kind of hubs are they?
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 06-21-2014, 02:52 PM   #3
tylervalo
Manual hubs, I think they are warn.
Old 06-21-2014, 03:45 PM   #4
rich weyand
Surprising. I thought Warn hubs were nearly indestructible.
Rich Weyand
1978 K10 RCSB DD.
Old 06-21-2014, 10:06 PM   #5
v30crewcab
v30crewcab's Avatar
why are you driving it in 4lo on pavement? that will break something. It binds everything up.
you probably need to take your hubs apart and make sure nothing is broke, or needs to be cleaned and regreased. they do need maintenance from time to time.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 06-21-2014, 10:13 PM   #6
tylervalo
It's really only 2wd since my rear drive shaft is disconnected
Old 06-22-2014, 12:13 AM   #7
buddy_1
buddy_1's Avatar
Probably stretched out the TC chain and its starting to jump a tooth at times. The front axle drive is designed to assist the rear drive axle. Now that your driving a front wheel drive truck, all the weight and torque is going to be too much for the chain to handle over the long haul.
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 06-22-2014, 07:23 AM   #8
tylervalo
I have a 205 tc.
Old 06-22-2014, 08:48 AM   #9
68Timber
I know the pieces fit
68Timber's Avatar
Originally Posted by tylervalo View Post
I have a 205 tc.
That is interesting. I was thinking it was the chain too. I'd pull the front cover and check the ring & pinion and make sure there's no broken teeth.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-22-2014, 11:43 AM   #10
donut
donut's Avatar
Also take a look at the slip joint on the front driveshaft. I also thought chain, but the spline connection on the slip joint may be worn. (for that matter, in a 30yr old truck, it all may be worn.)
Just for giggles, what are you working on?
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 06-22-2014, 01:36 PM   #11
tylervalo
Working on this
http://67-72chevytrucks.com/vboard/s...d.php?t=614810
Old 06-22-2014, 03:24 PM   #12
v30crewcab
v30crewcab's Avatar
more than likely you just need to clean and regrease the hubs. they are either sticking, or have some broken parts that are hanging up.
71 longbed 5.3 4l80
Old 06-22-2014, 08:13 PM   #13
donut
donut's Avatar
Hubs first, then other stuff. Odds are just what v30crew mentioned. Grease on my '73, had started to dry, hub operation was sketchy. Clean and re grease and all was good.
Fathers' 84 stripped out the front driveshaft slip joint.
