Old 06-22-2014, 05:57 PM   #1
Dirtkid93
exhaust leaks EVERYWHERE!
I drove my truck 14 miles to EDC las vegas (: awesome right? no... right as i got there my exhaust manifold gasket blew, my flange gasket blew, and probably something else. i stayed at edc until 5 in the morning, after listening to blasting music for 7 hours the sound of open headers didn't bother me, but sure bothered my neighbor driving into the neighborhood at 6 in the morning.. okay enough BS
i replaced both gaskets, tightened them to proper torque setting and it still sounds like its running open, i felt for leaks, flange was still leaking, replaced it again and had same issue, got fed up and put that rubber-steel ( similar to jb weld ) on my flange, ( bringing it to exhaust shop and they can deal with it (: ) still can't get manifold to stop leaking, i checked both surfaces, perfectly flat and crack free. any suggestions?
Dirtkid93 is offline   Reply With Quote
Old 06-22-2014, 08:27 PM   #2
66Submarine
66Submarine's Avatar
Re: exhaust leaks EVERYWHERE!
I didn't have any idea what "EDC" was, so I googled it; seems like people die there pretty regularly!
When you say
do you mean you have tube headers, or the factory cast manifold? (I also don't think I'd call a blown out gasket as loud as something with nothing after the headers/manifold!)
Assuming you have the factory manifolds; are the intake and exhaust lined up where they bolt together? I've heard of some people having trouble where they were misaligned and that caused a leak, but besides that I don't see why you would be having problems if both the surfaces are true and they are torqued down like they should be.
A common "fix" would be a little bit of high-temp (red) silicone or similar, but I really don't think you should need to do that if everything is good.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 06-22-2014, 09:28 PM   #3
Dirtkid93
When you say do you mean you have tube headers, or the factory cast manifold? (I also don't think I'd call a blown out gasket as loud as something with nothing after the headers/manifold!)
so decided that the 230 I6 is now going, i found a 305 sbc from an 86' monte carlo, will it bolt right in?
Old 06-22-2014, 09:41 PM   #4
66Submarine
Well, (as said before) it's an SBC, so yes. BTW; 1986 should also be a one-piece rear main seal, FWIW.
