Shock relocation
Anybody know shock angle or measurements for relocating rear shocks with 4" drop springs on 68 short bed
Old member
I wouldn't even mess with the stock locations if you dropped it 4". By the relocator shock mounts and you will be much happier!
I used 'No limits" and love it. ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Shock relocation
I kept the original shock locations on my 4" rear drop, added Belltech drop shocks, and haven't had any problems. Not sure relocation is necessary on this drop distance, unless that's just what you prefer. FYI
I did the cpp relocation kit on my '68. the kit was only $55 and it worked great. here is the before and after.
Sounds like the OP was wanting to fab some up. So her you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=437582 I did the uppers this way but made my own lowers with 3/16 plate, a punch press and press brake but you could get the same result by just using angle iron for the lowers. I have seen it done several different ways. Or just spend the $50 -60 on aftermarket parts that look just like these. Just depends on skill,material,and a little time.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
![]() Join Date: Nov 2012
I saw a thread here somewhere, I don't remember which one, but they just took the existing bottom mounts and swapped sides, flattened the ridge so they'd fit, then flipped them over. Then they redrilled new holes in the top mount and shaved alittle off. I'm sure someone here can direct you to this mod. I'll take another look and see if I can find it and post it later.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
Old member
Yea I did the dropped shock deal to when I first dropped my 71.
Does it work Yea, does it ride good. I'd say it rides OK. Does the shock perform as it should, no it has to much angle. Most people don't care though since they have a lowered truck. I wanted ride quality so I went with the relocator + the kit makes the truck feel better also in a curve since the shocks are further out. ![]() ![]()
#9 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Old member
If you use the No limit kit you can. What you see in the pictures is what is on my 71.
Thanks guys I got it figured out.I should have looked at the kit before I asked.it was a ccp bolt on pretty easy.
How well do you think the no limit kit wil work with a bagged truck? Are those blue shocks stock length?
#13 | |
laying low
![]() Join Date: Mar 2001
And with Andy's setup you have more free room to run exhaust over the axle.
#14 | |
Old member
![]() ![]() One of my favorite pictures of Hellboy!
#15 |
laying low
She's a beaut!
#16 |
Favorite picture of Hellboy,mmmm.... Okay, I'll go with that !!!!!
Merry Christmas everyone !!!!!!!!!!!!!!!!!!!
#17 |
[QUOTE=Andy4639;6434126]I would think it would be a wonderful improvement! Rob is a vendor here on the forum and drives the Hellboy truck. I even have been thinking about finding a coilover shock to replace the stock coils.
![]() ![]() What shocks are you running? Did you buy those with the kit? $149 plus $98 for shocks isnt cheap compared to the CPP kit. Very tempting to more easily route the exhaust up and over the diff. |
#18 |
Old member
Yes it's more money but I think it was well worth it. Yes I bought the shocks from them. The kit is worth every penny. Once You install it you will notice the deferance on the first curve you take. I even took my rear sway bar off...because it was interfering with the mounts but afterwards I was fine with it.
#19 |
good info here. and just in time. for the past few weeks i've been thinking about relocating my rears outboard it just makes sense that the closer too the wheel they are the better they would work.
I remembered andy putting pics of his setup before i was gonna pm you for the info but its all here in the thread ![]() one question though. i see that the no limit kit has the shocks tops at a rearward angle. with the way the trailing arms move/travel while going down the road i would think the shocks would perform better if they were either near vertical or perhaps angled slightly towards the front of the truck. btw hellboy is one sick ride i love hearing the rear end whine both the oe mounts and my ece relocaters both still have that forward angle. am i overthinking this or just being nit picky either way i would like too move my shocks not only too help the guys at the exhaust shop get over the rear but also to be differnt and have a great ride.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#20 |
Old member
Yes the shocks are full lenght truck shocks. I have had the No limit relocator now over a year and the truck rides great. I have thought about buying some coil over shocks for it but...can't seem to pull the trigger on them. I like the helper bags in the rear and thinking real hard on installing a set in the front coils.
You can see in the pictures how much room you have after moving the shocks out ward toward the wheels. One drive with the system and you will see what I mean. ![]() ![]() ![]()
#21 | |
![]() Join Date: May 2014
