Old 06-23-2014, 08:50 PM   #1
Orion88
Orion88's Avatar
79 dash recovery: Issue with VIN location
So from what I've found searching the internet, 73-78's had the VIN on the inside of the door, and 79-87's had the VIN on the top of the dash on the driver's side. BUT... LMC makes the same dash pad for 73-80. Even though LMC says this dash is for all 73-80 trucks, somehow I doubt there will be a hole for where the VIN is located on my 79. Do I have to find an original dash pad? I don't suppose I could use the 81-87 dash pad, could I? Any solutions, suggestions, or pictures would be much appreciated.
You gotta have fun while you're little!!
Orion88 is offline   Reply With Quote
Old 06-23-2014, 08:58 PM   #2
thefraze_1020
thefraze_1020's Avatar
Re: 79 dash recovery: Issue with VIN location
...or you can try Brother's, Classic Parts, etc.
I'm pretty sure Classic Parts at least splits up their dash pads into 73-78 and 79-80.
Cameron
1984 Chevy C20 Custom Deluxe
thefraze_1020 is offline   Reply With Quote
Old 06-23-2014, 09:00 PM   #3
71swb4x4
71swb4x4's Avatar
Call a vendor that works on these trucks, ask them, and then buy the dashpad from them. There are still a lot of good quality businesses out there.
I am not a 73-87 guy, so I can't offer much on which business to use. l have spoken with Wes at Classic Heartbeat and Paul at GMC Paul's about 67-72 trucks and they are very knowledgeable.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-23-2014, 09:20 PM   #4
Orion88
Orion88's Avatar
Sorry, I wasn't specific enough. All three vendors make a 79-80 dash pad, but none of them make a 79-80 dash pad cover, only 73-80. I'm not sure if I want to spend the extra $200 to replace the entire dash pad if I don't have to. So what are my options here?
Old 06-23-2014, 10:18 PM   #5
notallthere
I mounted mine with the dash out of the truck. Once it was stuck on I then cut the hole for the VIN.
notallthere is offline   Reply With Quote
Old 06-23-2014, 10:24 PM   #6
Orion88
Orion88's Avatar
Do you have a picture of how well it turned out?
Old 06-24-2014, 07:58 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
just to mention the pad does change design in th 80s
with the bezel changing too,headlight switch and wipers move
I am using a 89 pad in the 78,leaves it empty.
I know the setup i have fits fine,keeping the 78 bezel
don't see why a later pad won't work for you.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-25-2014, 08:55 AM   #8
notallthere
These are really the only ones I have. I can get better ones if you like. During a hot day the part around the defrost vent comes up.
Old 06-25-2014, 08:56 AM   #9
notallthere
Actually I do have to get better ones as I made some changes since this photo.
