69 gmc ls3\ t56
hi,
i am in need of info, i am trying to install a engine from a 10 camaro LS3 but the engine was purchased with no accessories, will all the front accessories from a truck based ls engine work on the camaro 6.2? thanks sean |
![]() Join Date: Apr 2005
Re: 69 gmc ls3\ t56
The 2010+ Camaro has the same offset as the truck, so yes they will bolt on.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Re: 69 gmc ls3\ t56
Is your truck getting a little up grade!!
Re: 69 gmc ls3\ t56
Thank you f or the reply,
So, any 2010+ truck with any of the 4.8, 5.3,6.0 or 6.2 will work? I need all acc brackets, alt power steering pump, starter, >>>>> ha ha yeah its getting a lil power upgrade...... ![]() |
![]() Join Date: Jul 2009
Re: 69 gmc ls3\ t56
The truck PS pump/alternator bracket will contact the Camaro L99 waterpump and Camaro throttle body. You can get around that by relocating the idler on the bracket and trimming the bracket. Just FYI that it's not quite a bolt-on.
