Old 01-10-2004, 08:32 PM   #1
19mike69
rocker replacement
are the rockers very hard to replace?....how does one get the old ones out and how are the new ones held in place?...are they welded or what?
he who dies with the most toys wins...
19mike69 is offline   Reply With Quote
Old 01-10-2004, 08:33 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
old ones are cut out new ones are welded in and from what im told as long as ya can weld and have reasonable patience its easy enough
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-10-2004, 08:46 PM   #3
Bryan68custom
Service parts in Denison sells a spot weld cutter, its a little pricey but works good. I am in the process of doing mine now if you would like to see let me know I am no expert by all means but am learning as I go
2004 Extended cab LS silverado
2001 Buick Lesabre
1968 Chevy Custom 10 LWB Anniversery model
2008 crew cab lt (rolling on dubs)
"The nice part about living in a small town is when you don't know what you're doing, someone else always does"
Bryan68custom is offline   Reply With Quote
Old 01-10-2004, 08:49 PM   #4
fast71
Drive it like U stole it
fast71's Avatar
I did mine and as long as you have that spot welding tool remover and a welder or panel bond its a breeze.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 01-10-2004, 09:16 PM   #5
billsbowtie
billsbowtie's Avatar
i have replaced several panels i cut the old ones out with a grinder and chisel and hammer they are most offen all ready about to fall off anyway i have always rivetted the new ones on
they are as strong as a weld just make sure every thing is lined up before you start pop rivitting it takes a good day to replace both sides after you get them rivitted in grind them down a little and cover with body filler sand smooth and primer
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 01-10-2004, 10:11 PM   #6
19mike69
see,i dont have a welder or access to one....thats why i was wondering if there were other ways to put them on....and according to yall,there is
Bryan68...i may have to check yours out and see whats up
Old 01-10-2004, 10:38 PM   #7
Maximum Overdrive
December 21, 2012
Depends on the tools you have at hand. I had no access to a welder or other tools so I cut my off with tin snips- yes tin snips- and rivited on the new one until I can get it down to the body shop and weld it up.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 01-11-2004, 07:53 PM   #8
billsbowtie
here is a pic. of my shadetree work
Old 01-11-2004, 08:06 PM   #9
19mike69
billsbowtie....thats looks pretty good....what do you do about where the rivts are?....im only putting together a daily driver,but want it to look halfway decent and hold up for a while
Old 01-11-2004, 08:17 PM   #10
billsbowtie
i have fixed about 25 of these trucks after you get all the rivitts in just grind them down a little not to much cover with body filler sand it takes a littel time just keep at it till you get done you will be suprized how strong it will be when you get done i wish my camera was working so i could send you more pics. thanks bill
Old 01-11-2004, 10:38 PM   #11
Blue Beard
Blue Beard's Avatar
the Eastwood Company has a spot weld cutter that makes it simple...........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-12-2004, 11:32 PM   #12
66nova383
If you have a spot weld cutter and a wire welder its fairly easy to do.Just make sure you fit the rocker panel to the door bottom and hold the rocker in place with screws don't weld until its all lined up perfect.it took me a afternoon per side .And use a spot weld cutter so you don't cause more damage.
66nova383 is offline   Reply With Quote
