Old 06-24-2014, 06:01 PM   #1
Metalaroundstone
Does rocker rocker panel have to be removed to fix kick and floor panels?
My 66 has good rocker panels, but rusted out kick panels and floor panels. Is it possible to use these repair panels to fix these problems without first removing the rocker panels? Can one get to all the spot welds that hold all the sheet metal parts together if you don't remove the rocker panel? To me it looks like the floor panel would not be as hard as the kick panel, which looks like it is sandwiched in.
Metalaroundstone is offline   Reply With Quote
Old 06-24-2014, 09:15 PM   #2
joesscamaro
Re: Does rocker rocker panel have to be removed to fix kick and floor panels?
For the floor pan, it's going to depend on how far into the the door sill the rust damage goes. Also, the inner rocker is part of the floor pan...is the inner rocker still in good shape? I'm right in the middle of my rust repairs also, and to the best of my knowledge, you can do the kick panel without removing the rocker. You're correct, it is sandwiched in-between the inner rocker and the bottom of the pillar. You'll have to obviously remove the bolts that bolt it all together, but I can't remember if it is spot welded behind there. I want to say no, but someone more knowledgable may chime in. Good luck on the rust removal journey!
joesscamaro is offline   Reply With Quote
Old 06-24-2014, 10:24 PM   #3
spookylynx
spookylynx's Avatar
I just got done doing the whole floor / rocker / rust repair job. From my experience... unless your inner rockers are good then everything needs to come out. I was going to salvage my original outers since they werent that bed but no go. also, as you dig if your kick panels are gone then your A pillar is probably gone too. Despite the repro / OE debate, new rockers are relatively cheap and after doing it, I would just tear the old ones off, put in new floors, work out and then replace the outer rockers.
spookylynx is offline   Reply With Quote
Old 06-24-2014, 11:07 PM   #4
Metalaroundstone
It looks like the PO put on new rocker panels but did not bother to replace the rusted floor or kick panels. Both have pretty bad rust, but it looks like the inner rocker part of the floor panel looks to be in good shape. I am just trying to save what is good and maybe save some time.
Thanks for the replies.
Old 06-25-2014, 10:00 PM   #5
ls60apache
hello my kick panels were spot welded to the inner rocker,i would also suggest removing outer rocker to replace.if not theres probably gonna be untreated rust that may come back to haunt you. good luck
ls60apache is offline   Reply With Quote
Old 06-26-2014, 09:49 PM   #6
spookylynx
spookylynx's Avatar
you might be able to cut out the kicks and save the outer rockers. The only thing I would worry about is a rusted out lower A pillar between the kick panel and the rocker. You could also try removing the outers CAREFULLY and save them. If they are replacements they may not have the 1,000,000 spot welds that the factorys did.
Give it a try, you can always cut more out. But just as many people here have said, "rust never sleeps" so if you kinda half-ass it, you will only get out what you put in.
Good Luck it's a tedious job, just take your time.
Old 06-26-2014, 10:50 PM   #7
Lugnutz65
Lugnutz65's Avatar
If the kick panel is rusted out, then you can be pretty sure the bottom of the A pillar is rotten too. You must decide whether you want to repair it properly or just make it look good. Both will look the same on the outside and only you will know, but it depends on what you want to end up with.
My kick panels had holes but my inner and outer rockers looked great. I removed the outer rocker to find that the bottom of the A pillar was crumbling rust.
My welding is not beautiful. I'm just learning how. But I'm getting it done and learning a new skill at the same time.
Here are some pics of mine.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-27-2014, 12:19 AM   #8
Metalaroundstone
I appreciate everyone's comments and opinions on this. It would seem that the best course of action is to remove the rocker panels and see what is under there. It looks like one of my rockers is only a couple of years old, but as I said before, the PO didn't bother to replace all the other rusty components when he replaced the rocker. Since it is not my style to cut corners, I will bite the bullet and do this job right. Thanks again for all the info. I really appreciate the help I receive on this forum.
Old 11-03-2014, 07:45 PM   #9
Ratpin
Ratpin's Avatar
I will be doing this soon as well. Thanks for the detailed pictures Lugnutz65!
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 03-04-2015, 10:01 AM   #10
Cuate
Sorry to but in but, On my 69 C10 the outer rocker panel looks good but the inner rocker panel has a few rust holes. It's mainly in the center of the panel not on edges. Can this be fixed from the bottom with out removing outer rocker panel?
Cuate is offline   Reply With Quote
Old 03-04-2015, 09:49 PM   #11
ImpalaJim
ImpalaJim's Avatar
Lugnutz65 may I ask why you cut that patch in 1/2 ?
ImpalaJim is offline   Reply With Quote
Old 03-04-2015, 09:56 PM   #12
Hollow65
Hollow65's Avatar
Here I thought I was the only one with the flinstones floor pan. Excellent info fellas. Thank you.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 03-04-2015, 10:27 PM   #13
Lugnutz65
Lugnutz65's Avatar
You are very observant, however I did not cut it completely in half. I had trouble making the outer rocker slip over the pillar patch, so the short answer is that I cut it nearly in half so I could shape the piece the way I wanted. The cut went through most of it. The section that was just on the front of the pillar was not cut. I could not properly shape the piece until I cut it since it is very rigid by design.
I am a novice welder but my welding has improved a lot since those photos were made. It seems my welder wasn't working properly.
I have a nicer welder now.
Old 03-05-2015, 12:46 AM   #14
ImpalaJim
ImpalaJim's Avatar
I had to do both sides of mine as well.
I don't have any pics of the dog legs though. What I did was get them to where the rockers liked them. then drilled and reamed the bolt holes. I like how you did the inside as well. I don't have pics but what I did was cut patches from a universal floor pan that I accidently ordered. so there curved instead of squared
Old 03-05-2015, 01:01 AM   #15
VonDog
VonDog's Avatar
If you remove the front fender, you'll be able to see the A pillar.
VonDog is offline   Reply With Quote
Old 11-02-2018, 12:50 AM   #16
Romo912
My A pillar is good on my 1971 c/10 however my outer rocker is bad . Anyway to replace the inner rocker without removing the A pillar? Sorry if i’m Butting in .
Romo912 is offline   Reply With Quote
