Re: 1985 Short Bed
Still making some progress on the truck, however slow, but progress anyway
![]() Join Date: Dec 2012
Re: 1985 Short Bed
Slow is better than none. It took me 1 year and a half between work and life. It is well worth it. Having the engine and tranny out will make the rest of your work easier.
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that! I like long walks on the beach, dinner by candle light, and poking dead things with a stick. |
#3 | |
Re: 1985 Short Bed
![]() looking good!
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
Re: 1985 Short Bed
Got a chance to work on the truck a little, a lot of wet weather here lately, and getting closer to getting the cab off. Progress included getting both doors off and all the cab bolts out but one. That last bolt made about 3 turns and froze up, want go in or out so my question is what do you guys do with something like this. Other problem is the inside bolt to the upper door hinge fell out of the socket and drop to the inner rocker, I think, so how do you remove this bolt or just leave it and replace it with another.
Re: 1985 Short Bed
After soaking the last cab bolt with pb blaster for about a week it still wouldn't turn, finally started spinning in the holder. Finally got it out but had to go a different route and after checking the bolt after removal replacement is in order. The next step is to get the carriage nut out.
