Closed Thread
Old 06-27-2014, 07:33 PM   #851
69chevytrucker
69chevytrucker's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by VWNate1 View Post
I delivered the spare un rusted , un damaged radiator core support to the new paint jail......
He says they're getting ready to bead blast my spare cab and begin working on it .
I have some ' better ' (not as loose) door hinges , is there any one who's re - bushing them ? .
I'd love to mail these away and get 'em back all new and tight again .
you can buy a bush kit and do them in like 20 min tops very easy to do tap the pin out the old bushings will be plastic and tap them out and then tap in new brass ones then tap in new pin done
69chevytrucker is offline
Old 06-27-2014, 07:40 PM   #852
BugzC10
BugzC10's Avatar
x2
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 06-27-2014, 09:18 PM   #853
9teen69
9teen69's Avatar
Finished up the Vintage Air install enough to get the system charged. Still in shock that there is cold air in the truck.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 06-27-2014, 09:33 PM   #854
Lee H
Lee H's Avatar
Nice, I love my VA AC. I usually drive around with the AC on and the drivers window down unless I'm on the freeway. Even when it's 100 plus it's nice and comfortable.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Old 06-27-2014, 09:46 PM   #855
colgad
colgad's Avatar
What brackets are you using for the ac compressor?
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 06-27-2014, 09:57 PM   #856
Lee H
Lee H's Avatar
Originally Posted by ItsRandy View Post
Finished the rear fenderwells today.
Bout time your getting that beast finished up. Looking great!!!
Lee H is offline
Old 06-30-2014, 09:46 AM   #857
VWNate1
VWNate1's Avatar
Thumbs up Door Hinge Repair
Thanx ! .
I thought the door hinges didn't get replaceable bushings until 1973 , we used to stock those (OEM bronze not plastic) as well as the check springs .
Who's the best vendor for this ? .
TIA ,
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-30-2014, 10:35 AM   #858
74baggedbug
Looking good, the vintage air was some of the best money I spent on my truck
74baggedbug is offline
Old 07-01-2014, 01:39 AM   #859
Gobuffalo
Gobuffalo's Avatar
I had to rebuild all the door hinges on my 70 Suburban. I bought the kits from Brothers in Corona. My pins were rusted to the hing so I had to drill them out. The new brass bushings were too big for the holes the plastic ones came out of. I used a drill a little smaller than the knurling on the bushing and they fit great. The pins were a little tight on the half that that the old pins were rusted into so I had to sand them a little. I used an old 3" long, 1/4" bolt that I cut the head off of, cut a slot in it about a 1/2" long, put some emery cloth in it, put it in my die grinder and sanded till the pins fit snug. The pins I got were a little long, so I just cut them to length. They work great. Took a couple hours to do all 6.
Gobuffalo is offline
Old 07-01-2014, 09:19 PM   #860
67Slider
67Slider's Avatar
Installed a temporary temp gauge. I put it in one of the ebay buckets so it doesn't look too trashy. I mounted it under the heater controls and just above the shifter so it looks like a tranny temp gauge. Had to replace the shifter cable too. Runs like a top again.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 07-01-2014, 09:25 PM   #861
69chevytrucker
went from this
to this
Old 07-01-2014, 09:26 PM   #862
Turbo1dr
Turbo1dr's Avatar
Since I just got my truck yesterday, I'm still assessing body rot and cleaning it out.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline
Old 07-01-2014, 10:21 PM   #863
Lanman1972
Lanman1972's Avatar
I like your choice in trucks! I put the passenger side door on mine today.
Lanman1972 is offline
Old 07-01-2014, 10:26 PM   #864
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
So, does that make it a temp temp gauge?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 07-01-2014, 10:41 PM   #865
70shortfleet
70shortfleet's Avatar
Why are you showing the driver side if you put on the passenger side door? lol:
70shortfleet is offline
Old 07-02-2014, 12:09 AM   #866
ItsRandy
ItsRandy's Avatar
Originally Posted by colgad View Post
Very nice work, super paint, how much did you add to them?
You know...I don't know how much I added. I know they are 18" wide now but I don't know how wide they were stock. Took four stock ones, cut them up and made two wide ones. Kinda' like the money I spent building the truck...took a big pile of money, cut it up and...you know the rest.
ItsRandy is offline
Old 07-02-2014, 12:19 AM   #867
BADAZ chevy guy
BADAZ chevy guy's Avatar
The original space between them would have been about 49". Just wide enough for a full sheet of plywood + a little.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline
Old 07-02-2014, 09:47 AM   #868
zellway
zellway's Avatar
I like it! I installed a bolt less bumper on my short bed. It's not for every truck but it looks great on your truck!
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 07-02-2014, 10:02 AM   #869
67Slider
67Slider's Avatar
Yes it does. Been fighting the wiring gremlins and didn't want to chance overheating before I replace the harness. But it's too dang nice not to drive her.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 07-02-2014, 10:05 AM   #870
VWNate1
VWNate1's Avatar
Post Door Hinges
THANK YOU ! .
For what it's worth , I often make things hone to fit by using 1,000 grit or finer taped to an old drill bit , well oiled then spin it in the hole with a drill motor ~ works like a charm .
-Nate
Geezer
VWNate1 is offline
Old 07-02-2014, 01:38 PM   #871
73737373
Brought this home a week ago: 70 CST, 396, posi, tach, buckets and cab roof lights!!!
Like I need another project.....
73737373 is offline
Old 07-02-2014, 01:55 PM   #872
JWSmith
I picked up my seats, headliner, and visors from the upholstery shop. Not ready to put them in yet, but I picked them up.
JWSmith is offline
Old 07-05-2014, 06:05 PM   #873
nicks diner
nicks diner's Avatar
Finally got the cab and chassis back from the body shop, mechanic dropped in a 406 roller. surprisingly the hooker headers fit like a glove, he was very surprised for some reason. Just waiting on the carb and hook the new gas tank and hopefully GOOD to go.
nicks diner is offline
Old 07-05-2014, 06:42 PM   #874
vidman
vidman's Avatar
The brown truck showed up the other day with goodies from Moser..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 07-05-2014, 07:37 PM   #875
sKnNyPpY
sKnNyPpY's Avatar
Refurbed an old gas cap with a new rubber seal cuz I couldn't wait for my new one. Got the new one today and it fits nicely. Changed out a burned out a/c fan switch and fuel filler neck seal. All the parts were from GMC Paul's, nice fit and price.
I need a lower profile screw to hold in the ac switch in the bottom hole because it hits a little when trying to switch the fan to high. I soaked the rubber seal in hot soapy water and it popped on nicely in just a few minutes thanks to advice from the board.
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline
Closed Thread
