Electirc Choke help
I have question.. After repairing and cleaning up my wiring. I found a wire that wasnt hooked to anything. traced the wire.. well it for my electric choke on my carb. I assume this wire is to have 12v at ign on/run ?? would if matter where I get my 12v from.. I was just going to run a new wire to fuse panel. Hopefully this is the issues of my truck bogging down on accel. Thanks in advance !!
64 C10 Stepside 350/4psd Driver/Project on air. Dom bags, Dual Viair and AccuAir 08 Ford F150 Limited- F-word ! Daily Driver .......................____ ..........._______l/ ![]() ...........|_/(0)\_ll____/(0)_l. |
Re: Electirc Choke help
Yes. The choke wire needs to come on with the switch. You can hook in in the fuse panel but it needs to be fused.
This thread was added to the The Engine Bay category of your 60-66 FAQ Index.
-W NOTE : if this link changes in the future, look for the sticky at the top of the 1960-66 Message Board. |
You could tap power from the choke but the heating element draws a lot and will drop the voltage to the coil wire unless it is sized up accordingly.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
