fuse box/panel location on 1955-56?
where would the fuses be located on a 1955-56 chevy truck? thanks I cant seem to find one under the dash of my truck
![]() Join Date: Aug 2010
Re: fuse box/panel location on 1955-56?
In the headlight switch
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
Hollister Road Co.
Back then a fuse panel consisted of a 3 or 4 fuse board and it was optional equipment
all lights are protected at the headlight switch
vacuum wipers require no fuse electric wipers, heater and radio were options, if you have either from the factory there should be a 3 or 4 fuse panel above your brake pedal
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
just posted this in another thread
seeing as you can't find a fuse panel in your truck, you can add one by wiring it directly from the battery or starter. local parts store may have a 4 fuse panel. you can also use inline fuses but they get a little confusing when you add more than a couple.
i would not add to the current load on the old wiring. lots of us have come off the headlight switch or the horn relay to add circuits, but i believe your asking for trouble by doing this.
