Old 06-30-2014, 02:07 PM   #1
Yellow '67
Yellow '67's Avatar
'67-'72 Lower Control Arms
Are the C10 1/2 ton control arms the exact same configuration ie, measurements, thickness, shafts & ball joints as a C20 3/4 ton? If not, what's different?
Yellow '67 is offline   Reply With Quote
Old 06-30-2014, 05:15 PM   #2
67 cst swb
67 cst swb's Avatar
Re: '67-'72 Lower Control Arms
Ball joint hole is larger on the 3/4 ton
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 06-30-2014, 05:16 PM   #3
JointTech
JointTech's Avatar
the shaft that attaches the LCA to the crossmember is bigger on C20.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 06-30-2014, 06:54 PM   #4
Yellow '67
Yellow '67's Avatar
Thanks for the reply guys! So am I to understand that by using the larger C20 parts, one can adapt the C20 arms to a C10 suspension?
Old 06-30-2014, 07:03 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
No.
C10 spindles require C10 balljoints,... and they only fit C10 a-arms.
You could convert your C10 to a C20 8-lug truck,... by using C20 lower a-arms.
Keith
Convert to disc brakes.
Old 06-30-2014, 09:02 PM   #6
Yellow '67
Yellow '67's Avatar
Gotcha!
