Old 06-29-2014, 06:00 PM   #1
Ernie76
Any pics of spot welds on the bed
Hi im taking my bed apart...im trying to locate the spot welds
I know theres a ton of bolts to unbolt
Thanks in advance
Ernie76 is offline   Reply With Quote
Old 06-29-2014, 06:25 PM   #2
Nukes16
Nukes16's Avatar
Re: Any pics of spot welds on the bed
Not really sure what you mean. The box has no welds connecting the panels. It can simply be unbolted.
Nukes16 is offline   Reply With Quote
Old 06-29-2014, 06:28 PM   #3
Ernie76
I was told it has spot welds on the rear by the tailgate but cant seem to find them
Old 06-29-2014, 06:31 PM   #4
Nukes16
Nukes16's Avatar
Not that I recall. Just the bolts and the seam sealer hold everything together. I didn't have to cut or grind anything.
Old 06-29-2014, 06:33 PM   #5
Ernie76
Ill check that then cause I have to replace the driver side
Old 06-29-2014, 06:37 PM   #6
Nukes16
Nukes16's Avatar
It does tuck and fold in a couple of spots near the inner bolts at the back but that's all. Good luck.
Old 06-29-2014, 06:41 PM   #7
Ernie76
Ive already took out the bolts and ive try wiggle it back and forth and doesnt come out
Old 06-29-2014, 06:46 PM   #8
Nukes16
Nukes16's Avatar
There are some hidden bolts underneath and inside. They are difficult to see.
Old 06-29-2014, 06:47 PM   #9
Ernie76
Ive already check and couldnt find any more
but ill keep trying
Old 06-29-2014, 07:12 PM   #10
Desperado454
Desperado454's Avatar
Pretty sure there's a weld where i drew the arrow, been awhile since i took mine off.
Twin Turbo '76 C10 Build
'28 Model A Build
-Brooks
Desperado454 is offline   Reply With Quote
Old 06-29-2014, 07:16 PM   #11
Ernie76
Oh ok thank you...it looks like its in the inside not the outer part
Old 06-30-2014, 11:48 PM   #12
bigblock73
yeller
bigblock73's Avatar
There are two spot welds at the rear of the bed, where the stake pocket channel meets the bed floor.
bigblock73 is offline   Reply With Quote
Old 06-30-2014, 11:51 PM   #13
bigblock73
yeller
bigblock73's Avatar
Here is a scan of an article on my site...step 9
http://73-87.com/7387garage/exterior.../bolton_04.jpg
Old 07-01-2014, 12:33 AM   #14
Ernie76
Oh ok thanks I see they are by where the tailgate enters next to it
