where did you mount your electric fan relay
theres more room on the drivers side of the coresupport but then I have to run wires across the rad. I was thinking below the battery box but then I remembered the inner fenders are pretty close there.
2WD Jimmy
![]() Join Date: Mar 2005
Re: where did you mount your electric fan relay
I mounted mine below the battery. It fits fine.
I put mine on the fender just back from the battery on the passenger side. Not a show truck, so it didn't matter if i could see them, and easy to get to.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Still Learning
I mounted mine behind the glove box along with my vintage air relays. I had to run a bunch of wires but it worked out good. Mine has low 3 relays.
i went ahead and mounted it under the battery box. Ill get some pics tonight.
looks like a rats nest anyway...
![]() ![]() put the headlight relays behind the battery while I was playing with fun wires... sneaked it behind the rad. ![]() |
